Got the runs!
Old Aug 8, 2007 | 04:53 PM
Unique Artwerkz's Avatar
Default Got the runs!
I cleared this mirror ive been practicing on....got a bad run in 2 spots....tried sanding them with 1500 by hand, then 800 by hand, barely doing anything, can I hit this with a DA with maybe 600 grit?
Old Aug 8, 2007 | 05:19 PM
vsmhatched's Avatar
Default Re: Got the runs! (Unique Artwerkz)
you can use a razor blade to cut therun out..then sandit with 800 wet....that should do the trick, then either buff or re-clear
Old Aug 9, 2007 | 02:10 AM
Haha man I didnt think you could do that....awesome, ill give that a try, thanks!
Old Aug 9, 2007 | 04:14 AM
WihaSi's Avatar
Every run I've ever encountered, you can only get them close to gone. You will always be able to see them. Your best bet is to block them down then re-spray the panel/mirror, whatever you're working on.
Old Aug 9, 2007 | 10:43 AM
DO I sand down the clear or the whole thing?
Old Aug 9, 2007 | 11:12 AM
vsmhatched's Avatar
Default Re: (Unique Artwerkz)
down the clear...and try not to cut into the base coat...otherwise you have to re-base it too
Old Aug 9, 2007 | 11:43 AM
Sweet I think I can handle it. Will 320 be okay? Then maybe wet sand it with a higher grit to smooth it back out?
Old Aug 9, 2007 | 03:22 PM
Bigblockhatch's Avatar
No if u use 320 u will need to rebase the part......You can buy a thing called a run file or denibber....It will only cut at the run till it gets the run flat.Then you can block with 800 then 1000,1500,2000 and then buff.
Here are a couple that i found on Ebay....This isnt to sell these just so you know what you will need....http://cgi.ebay.com/ebaymotors/Paint...spagenameZWD1V
Old Aug 9, 2007 | 04:47 PM
Sweet thanks!!!!!! Hopefully ill get this straight and finished up.
Old Aug 9, 2007 | 05:44 PM
patrickburke2007's Avatar
w0w..finally i've seen this thread... i've encountered the same problem..atleast now i know how to deal with it.. wanna thank you guys for th infos...
Old Aug 10, 2007 | 09:03 AM
l2edken's Avatar
haha i almost died when i read the title...
Old Aug 10, 2007 | 10:07 AM
Haha I figured it would get some attention lol
mattjohnston
Engine Management and Tuning
Jul 17, 2010 03:09 PM
heyitzspikey
Paint and Body
Dec 27, 2008 04:49 PM
Burgh
18
Nov 11, 2003 06:42 AM
hydroflip
Oct 11, 2002 07:23 AM
