Need a little help
Old Mar 8, 2009 | 03:04 PM
slowassciv33's Avatar
Default Need a little help
Alright ill give u a fast run down on the situation. my brother wanted another civic so found a 99 ek shell for 700. Not bad right? well the car use to have a remote start and the owner b4 started it while it was in gear. It ended up hittin n to a back of a truck bending the rad support n the fender support. We got basically everything lined back up but the pass side was a little off. So we hit up the junk yard with my drill and spot weld drill bit and got the peice we need for 15doll hairs. Now the real question is how do i remove the old peice with out fully drilling thru the peices? and if i happen to is it a easy welding fix?
and this is how its off the rest is find just the front of the hood is whats not lining up
P.S: DONT MIND THE ZIP TIES HOLDING THE HEADLIGHT UP ITS BROKEN AND JUST USED AS A MOCK UP FOR NOW
Old Mar 8, 2009 | 03:46 PM
kmt63's Avatar
Default Re: Need a little help
your going to remove the bent one just like your junk yard piece.dont drill through the panel.underneath.when you get the bent one off.grind the dimples off with a grinder and a flap wheel.install your new part.when satisfied with the fit.weld through the holes and fill flush with the top part.grind the welds flush and your done.
Old Mar 8, 2009 | 04:01 PM
yea i was gonna use my wiz wheel to remove most of the bent metal
Old Mar 8, 2009 | 04:24 PM
kmt63's Avatar
you will want to use your spot weld cutter to remove the parts that are spot welded to the under laying panel.yea you could get the majority off with your cut wheel.
Old Mar 8, 2009 | 04:27 PM
yea ill keep adding pics to ..it should take care of the fender ..i hope lol
palisoc05
Detailing
Jul 30, 2012 09:33 PM
shiux
Nov 20, 2008 06:45 PM
00b18ek
Jun 24, 2008 10:43 AM
WestEndStreetTouge
Welding / Fabrication
May 22, 2008 07:53 AM
Francesco
Honda S2000
26
May 16, 2006 05:09 AM
