need help on 1st time primer
Old Feb 1, 2010 | 04:14 AM
mr.carvin's Avatar
Default need help on 1st time primer
i need help on what to get to primer my 94 honda accor wagon and i one door do match with rest of them plz help
Old Feb 1, 2010 | 10:18 AM
FullMetalJack's Avatar
New User
Default Re: need help on 1st time primer
I use Mar-Hyde Ultimate 2K primer on all my projects. It's fast drying, High build, excellent adhesion, and easy to sand. You will also need the Ultimate 2K Catalyst and urethane reducer, and mix them in a 4:1:1 ratio. That's my advice on primer anyway.
Old Feb 1, 2010 | 04:59 PM
mr.carvin's Avatar
okay i need to what sand paper to get also
Old Feb 1, 2010 | 07:15 PM
delsolproblems's Avatar
Sand or scuff every single spot with 320 grit before priming. Unsanded areas will look glossy until they are scuffed. Get some black spray paint to use for a guide coat before sanding the primer. You spray a very light mist over the primed area and just let it fall onto the primer. It will cover the area in tiny black flecks. Once you sand off all of the black, you know you've sanded everywhere. Any divits or other low areas will still have black paint on them after sanding and should be repaired before painting. Primer is usually wet sanded with 400-600 grit and a painter's block depending on the tech's preference. Coarser grit helps the paint stick better and finer grit shows fewer scratch marks. GL
Old Feb 2, 2010 | 10:12 AM
mr.carvin's Avatar
okay thanks for that tip
Old Feb 3, 2010 | 04:41 PM
New User
You should use a sanding block with 320-400 grit paper on it. and you will be able to see where you've sanded because as soon as you touch the primer with the sandpaper it changes color and you will see the high and low spots (lows won't have scratches and the primer will sand off on the high spots). If you want to take the extra step of spraying an extra time that's fine, but you could just prime it and scuff it with a 3m scuffing pad before you paint. and also remember, the better the undercoat looks, the better top coat will look. What paint are you going to use?
Old Feb 5, 2010 | 10:27 AM
mr.carvin's Avatar
i'm going from light green to darker green
Civic-Kids
Paint and Body
Jun 13, 2009 12:00 PM
teggy182
Mar 5, 2006 02:29 PM
Kirei
Sep 27, 2003 09:21 AM
DaveF
Sep 23, 2003 03:15 PM
90-CRXSi
Jan 20, 2003 08:42 AM
