Need an answer to this problem...
Old Jul 29, 2007 | 12:31 PM
Hatchman98's Avatar
Default Need an answer to this problem...
I have a 98 Civic Hatch. It was in a minor front end collision a few years ago and since then the drivers side wheel sits further back then the passenger side wheel.
I was told that it is the cross member. Has anyone ever had this problem? Where would i find a cross member fairly quick? Any help is appreciated///thanx
Old Jul 29, 2007 | 01:18 PM
jdmturbo1127's Avatar
Default Re: Need an answer to this problem... (Hatchman98)
I had this same problem a few years ago when I slid into a curb. Might not just be the cross member. Take it to a alignment shop and they should be able to tell you what bent or broke.
Old Jul 29, 2007 | 01:23 PM
Lost_clearance's Avatar
your controll arms might be bent it will take a lot to bend the cross member,
Old Jul 30, 2007 | 04:56 AM
WihaSi's Avatar
Default Re: (Lost_clearance)
I would check control arm, knuckle, and strut first. Then look into the cross member.
Old Jul 31, 2007 | 08:57 AM
Hatchman98's Avatar
Default Re: (WihaSi)
if it is the cross member ... is that sumthing hard to replace, i heard its a pain in the *** to replace
Old Jul 31, 2007 | 12:34 PM
WihaSi's Avatar
Default Re: (Hatchman98)
Well in my estimating system at work, it's listed as 4.5 hours in labor, and I believe there is welding involved.
sicksiguy
10
Jun 3, 2016 01:46 AM
dHaybee
Suspension & Brakes
Apr 7, 2011 02:07 PM
liljohn850
10
Jun 18, 2009 08:11 AM
hondmywrld
14
Sep 12, 2007 09:30 PM
00CivicGirl
May 4, 2006 06:49 PM
