horrible problem, removed tint, second layer of ink?
Old Aug 17, 2011 | 01:17 PM
(. )( .)'s Avatar
Default horrible problem, removed tint, second layer of ink?
Ok I have a huge problem, I took off the tint off the rear hatch window of my dc4, but the top of the layer has a weird second coat of sticky ink with doesn't flake easy (and if i do flake it, its about the size of the tip of a needle.) nor does it come off with cleaner, such as Windex, soap, wheel cleaner (i got desperate) i even used paint stripper!!!! NOTHING WILL TAKE IT OFFFF.
I pulled the tint, i got the whole sheet of film off, but the top of the window has this purple stuff on it, about 9" of it. It looks like an eyebrow but in the rear..
Has anyone ever had this? can i sctratch my window if i use a blade? what to do!
Old Aug 17, 2011 | 01:27 PM
Builda'Teg_92's Avatar
Default Re: horrible problem, removed tint, second layer of ink?
I just got done removing mine. i dont really mention it in my thread, i should have done a little DIY. O well.
just go to harbor freight buy the 12$ heat gun they got, start using it in the corner OF THE OTHER SIDE OF THE GLASS. DO NOT DO IT ON THE SIDE WITH THE FILM. Its still takes a little time but each piece is pretty big. i would say about 3-4 hours. The slower you go the faster you will get done, peel slow.
But i also dont know the extent of the damage you have done to it so far so it may vary.
Old Aug 17, 2011 | 02:05 PM
(. )( .)'s Avatar
thanks for the reply man, but the problem is..is that I took off the plastic tint film..it peels off in 3 pieces. it left a purple residue that doesn't come off. at first i though it was just glue with purple ink, but it wont come off in pieces..i think i might just get a new glass for it off of CL..
Old Aug 17, 2011 | 02:19 PM
Mmmmm intresting mine came off in 2 pieces (the film then the sticky purple stuff)...im sure the heat gun can help mop up the goo.
I just hate removing windows ha, but yea if i got a good deal on a clean one and a free day i would probably do it. im still picking little left over pieces off my glass, what a pain.
Old Aug 17, 2011 | 02:32 PM
si.hatch's Avatar
Goo gone(can be found almost anywhere walmart cvs walgreens) and some razor blades. Should take up to and hour.
Spray goo gone on the window liberaly and start scrapin
Old Aug 18, 2011 | 09:21 AM
<MeanDelSol>'s Avatar
Purple film residue is from the use of cheap tint. Use shampoo and water out and spray generously and scrape off. Watch out for the defroster if you scrape them off they won't work!
BTW Lumar is one of the best company to make tint film
Old Aug 18, 2011 | 10:43 AM
(. )( .)'s Avatar
ill try goo gone for sure, I'm scraping the whole rear window, I have most of it gone, I just need to get the edges. ill need it when I do all the other windows along with a steamer.
yeah removing a window sounds like a PITA, ill stick to the pros haha. what I meant about I removed it in 3 pieces is that, it came off in 3 huge pieces but left purple crao everywhere, if i would have used a heat gun, i could have avoided this whole mess
lumar? i doubt the shops by me carry that, all the shops by me are pretty ghetto, ill have to go to a fancy place to get good quality stuff.
the purple residue is over the defroster so I'm not even going to scrape near there.
Old Aug 18, 2011 | 06:59 PM
slapaho_ca's Avatar
what u need to do is spray your window with windex. next put a black platic bag over it. then you let your car sit for a whole day while the sun is doing its job. a day later your whole tint will come off.
Old Aug 21, 2011 | 07:16 PM
00blksicivic's Avatar
try some goof off and a white 3m scuff pad, its glass safe.
Old Aug 22, 2011 | 10:10 AM
(. )( .)'s Avatar
I still have bits and pieces, I'll try this method today.
so goo-gone and goof-off..some intersting names here guys. ill look for goof-b-gone while im at it too
doods!
if other things dont work ill opt for this
Old Aug 22, 2011 | 11:07 AM
If you're having this much trouble just use a steamer..that WILL work.
Old May 15, 2013 | 11:25 AM
mail4hemanthr's Avatar
Hi,
I have honda 2002 accord and tried to remove the rear window tint. First layer came off very quick when i had soaked the window with soap solution and garbage bag. But, the second layer is being a pain.
I bought below item from menards as per the forum's suggestion. This doesnt help either... any suggestions?
http://www.menards.com/main/paint/cleaners-thinners-removers/paint-stain-removers/solvent-based/rust-oleum-aircraft-remover/p-1963198-c-8159.htm
Old May 19, 2013 | 06:51 AM
danyn's Avatar
YES--the steamer was effective on my 16 year old baked on tint. Target has a handheld fabric steamer for $29.99. The side and canopy windows peeled with heat gun approach but no doing on the rear. Steam up the whole car, rear window area and the second layer will eventually loosen
Old May 19, 2013 | 01:53 PM
Let me try
Old May 22, 2013 | 11:16 PM
DriftKnightX's Avatar
this might help
IHEARTMYHONDA91
Nov 11, 2008 08:27 PM
92ehatch
Nov 1, 2005 06:16 PM
dip-set
Nov 8, 2004 10:30 AM
Kimbo
11
Mar 31, 2004 12:01 PM
acme
Nov 4, 2002 06:39 AM
