Honda Civic si 2000 Bulkhead
Old 06-04-2013, 02:51 PM
SI-Freak's Avatar
Icon2 Honda Civic si 2000 Bulkhead
So I got in a small accident in my 2000 honda civic SI. I checked the damage.
The Beam, Fender and upper and left panel of the bulkhead were damaged. I was wondering what other parts are behind the left panel bulkhead?
Old 06-04-2013, 05:01 PM
thatsahonda's Avatar
Default Re: Honda Civic si 2000 Bulkhead
the photos do not load
Old 06-04-2013, 06:44 PM
Grade50's Avatar
The biggest concern will be your longitudinal frame rail. Is it bent at all? Your engine mounts attach to this rail and if it's bent, your mounts will start ripping if not already. Dont ask me how I know!
Old 06-04-2013, 07:25 PM
SI-Freak's Avatar
Sorry about the pictures, it's my first time and there is no attachment tool. You can right click and open in a new tab to go to the Facebook page where the photos are.
I believe the rail is bent only at the part where the beam bolts on to. You can view the pictures by reading on top of this paragraph.
Old 06-04-2013, 10:40 PM
Ryank327's Avatar
Heres your pics OP, delete the links to your FB profile, not a good idea to link to it on forums and such. Also that isn't your bulkhead, that is the Rad support. It's hard to tell the damage from the pics. Heres a replacement Rad support to give you an idea what it is.
http://www.partsgeek.com/mmparts/rad...nda/civic.html
But if you can put your bumpers and fenders back on and everything lines up fine I wouldnt even worry about it. You can always take it to a frame shop to have them check it real quick.
Old 06-05-2013, 12:51 AM
SI-Freak's Avatar
Thanks for uploading the pictures. I could not figure out how to paste them directly like that. I have the single piece that you see under the headlight that shows the damage. From what I have seen the part behind it is bent in slightly. The part behind it is sort of like a rail or a metal plank stuck to another that is welded on to the backside of the damaged part. Where it welds is where it got slightly bent. i don't think its too much damage that I would have to buy it but I will let you guys know. I'll take the car to a body shop for a quote on replacing the part I got and if they could straight everything out.
Jap_Spec_Imports
05-19-2009 06:23 PM
kaliboy562
05-07-2007 09:55 AM
kaliboy562
05-07-2007 07:01 AM
cooldude3525
05-05-2006 10:44 AM
Quick Reply: Honda Civic si 2000 Bulkhead
