the thingys below the window externally.....like a trim sort of...
Old Dec 14, 2007 | 09:07 AM
g0tgot's Avatar
Default the thingys below the window externally.....like a trim sort of...
how r you suppose to paint these? usually flat black and chrome metal underneath...usually paint chips off
Old Dec 14, 2007 | 01:13 PM
alscrx's Avatar
Default Re: the thingys below the window externally.....like a trim sort of... (g0tgot)
thats piece is plastic and needs to be painted with a flexible paint or dyed!!
Make sure you prep it right.
Old Dec 14, 2007 | 10:31 PM
Pockets's Avatar
it's called a belt molding, you can scrape all that peeling crap off and trim black it.
Old Dec 15, 2007 | 04:54 AM
g0tgot's Avatar
nice....thanks guys.....tried using regular paint before...it doesnt stick....just flakes....
Old Dec 15, 2007 | 06:05 AM
Crxkid90's Avatar
Default Re: (g0tgot)
this is gonna sound like a really noob question but how do you remove these pieces with out breaking them??? are they clips or something?
Old Dec 16, 2007 | 09:18 AM
boosted_dc2's Avatar
Default Re: (Crxkid90)
theres a tool you use, its shaped like a flat wide hook. you pry them off from the inside on the botom. sometimes you can get them off without the tool. and sometimes there is a screw holding it on at the end.
Landon
Old Dec 16, 2007 | 11:41 AM
jrmtegra's Avatar
Default Re: (boosted_dc2)
yeah, its a pain to get them off trying to explain it without showing. if you feel you might break them, try having a local shop do it for you. if they run good shops they should have someone do that for you. it wouldnt take but about two mins a side. Trim black paint is what you would use. if you sand it to the metal, you will need to spray a LITE coat of etch primer on the metal. most paints dont stick well to bare metal
reversal
Paint and Body
Apr 1, 2012 07:53 PM
newbie224
10
Jun 20, 2009 10:16 AM
emooheo
Paint and Body
13
May 25, 2008 04:54 PM
EtaK
Aug 6, 2004 05:22 PM
brinks
Feb 21, 2003 09:18 PM
