Help!!! Bad oxidation
Old Nov 2, 2011 | 04:55 PM
1slowcrx's Avatar
Default Help!!! Bad oxidation
What compound do I use or is wet sanding needed? I have a power sander/polisher also.
Old Nov 2, 2011 | 05:32 PM
joeshmo's Avatar
Default Re: Help!!! Bad oxidation
That's clearcoat failure. Needs a repaint. No rubbing compound will bring back shine. Very, very, very common on 90s hondas.
You could try wetsanding away the "oxidation" to fresh clear coat and applying opti-coat or even a new clearcoat and then blending in but that's a temporary fix at best.
Old Nov 2, 2011 | 09:28 PM
1slowcrx's Avatar
It's a 03 TL . What grit you recommend sanding with?
Old Nov 3, 2011 | 03:25 AM
jwicecold's Avatar
damn, shitty. I hate when this happens. I assume this is what happened to my 94 accord ex, cause when i bought it they painted it matte black! im now going through the hassle of doing all the body working and trying to get it re-painted properly!
Old Nov 3, 2011 | 10:06 AM
joeshmo's Avatar
Can you post a bigger picture of it and the surround area OP?
Old Nov 3, 2011 | 06:49 PM
jasoncrashtech's Avatar
400 grit wet or dry then a grey scotch with some soap and water. some use 600 after 400 but both work fine. make sure to rinse good so there is no soap left on panel. wax grease remover, seal, base, clear , yodda yodda
LandHard
Paint and Body
Apr 26, 2012 03:51 PM
PHILEE
Paint and Body
14
Apr 26, 2008 05:16 PM
1badassEG
Paint and Body
Oct 17, 2007 08:04 PM
B18CivicEH2
Paint and Body
Apr 25, 2007 10:18 AM
