frame pulling for front bumper frame
Old Aug 6, 2008 | 08:39 PM
marsvolta1fan's Avatar
From: Boyle Heights/East Los Angeles, CA, united states
Default frame pulling for front bumper frame
how much does it usually cost to pull the front bumper frame part?
cause my hood and bumper dont alight right cause its salvaged.
I went to a guy that will charge me $250 to pull the frame
and align my hood, fenders, and bumper.
Old Aug 7, 2008 | 07:17 AM
Irritated_Onion's Avatar
Default Re: frame pulling for front bumper frame (marsvolta1fan)
That price sounds okay.
Old Aug 7, 2008 | 05:11 PM
octaneaccord02's Avatar
You mean put it on a frame machine? Frame machine is really expensive like 2-3k. $250, do it!
Old Aug 8, 2008 | 06:31 PM
perfect then ill do it!!!!
Old Mar 2, 2009 | 07:06 PM
HCKRU's Avatar
what shop did you go to, i have the same problem due to an accident and the company fixed the OEM front, but i did front end conversion and bumper and the hood don't line up. i need a shop too 250 sounds like a great price.
Old Mar 3, 2009 | 01:45 PM
dc5r2002's Avatar
Frame work here in Philly is around $90 bucks and hour that price had to be for a big hit.
Depending on what it is that is bent you might not need a frame machine take some measurments and make sure the front end x's out. Measure from the hood hinge bolt hole to a hole for the light or something else up there make sure there is a hole that is symetrical to it on the same side and measure it should be the same thre is only a 3mm allowance then measure from the hinge bolt to the same side light bolt they should also be the same it will tell you a lot if one side is way shorter then the other. Its hard for me to explain but hopefully this will help if you know a tech ask if they can tram out your front end.
Old Mar 3, 2009 | 01:49 PM
HCKRU's Avatar
thanx man will measure today.
aznkid4now
Jul 19, 2009 12:27 PM
Rays_07
Paint and Body
Feb 24, 2008 05:56 PM
pccheng
Paint and Body
Nov 8, 2007 02:46 AM
thatwhiteguy
Sep 12, 2006 11:50 AM
nYcacCordvTeC97
Mar 18, 2002 06:13 PM
