Fixable without welding?
Old Apr 19, 2009 | 05:55 PM
All-Motor-Junkie's Avatar
Default Fixable without welding?
I parked in parking structure for work came out and saw this. it happened about a month ago, i want to fix it, is it better to buy a new car without rear quarter panel damage or is this a viable fix?
thanks in advanced!
Old Apr 19, 2009 | 05:59 PM
fav6052's Avatar
Default Re: Fixable without welding?
definitely doesnt need to be welded. well sorta, id use a stud welder that welds on copper studs and then use a slide hammer to pull it out. its going to take some playing with.
Old Apr 19, 2009 | 06:03 PM
The rear quarter panel is accessible through the trunk. Do you grind the weld marks off the rear quarter panel after you've pulled them out? If so then it seems like you might still have to bondo this area? Wouldn't it be more viable to just push the dent out as much as possible and then just bondo smooth, thanks in advance!
Edit, anyone in socal willing to take a look at this?
Old Apr 19, 2009 | 06:13 PM
fav6052's Avatar
youre going to need bondo either way. you could try to push it back out. but i own a 95 prelude and have done rust repair in that exact spot and its not the easiest spot to get to from in the trunk. it is doable tho.
Old Apr 19, 2009 | 06:22 PM
how much do you think it will cost to look "normal" ?
Old Apr 19, 2009 | 07:30 PM
fav6052's Avatar
I have no idea. Im not a body shop. Id say you need to repaint your whole car if youre going to paint that 1/4 panel. From what I can see, your paint is pretty seasoned. Fresh paint on just the 1/4 would stick out like a sore thumb.
Old Apr 19, 2009 | 07:33 PM
ohh yeah i have 24.87 different shades of black on this car, i was waiting till i was in the market of paint. i just dont want to spend like 2000$ id rather buy a clean shell for less then half of that lol then part out and make money back,
Old Apr 19, 2009 | 09:24 PM
DynastyRacer22's Avatar
this is why i hate parking at work i get new dents everyday
Old Apr 22, 2009 | 05:37 PM
precisionsc54's Avatar
easy fix. Pop it out fill and spray
Old Apr 22, 2009 | 07:24 PM
shocker911's Avatar
you should be able to get alot of it out with rubbing it from the back side then a lil body wrk and it will be back to new
Jameson
Oct 4, 2008 09:45 AM
PURO~SURCAL
Apr 28, 2006 05:03 PM
91bentcrx
13
Oct 12, 2004 06:56 AM
JeremyL
Apr 1, 2004 06:24 AM
LSpimpTEC
May 20, 2003 12:06 PM
