Does anyone know how to remove this?
Old Feb 12, 2008 | 09:10 PM
Nameless Warrior's Avatar
Default Does anyone know how to remove this?
This is a black integra hood. It looks like it has some oxidation problem. What is the process to revive the hood?
TYIA
Old Feb 12, 2008 | 10:27 PM
toyomatt84's Avatar
Sanji
Default Re: Does anyone know how to remove this? (Nameless Warrior)
Re-paint. The clearcoat is flaking off, not oxidizing.
Old Feb 12, 2008 | 10:29 PM
aNDrewCivcDx's Avatar
Thats the clear pealing off... Sand it down with 400 Grit Wet, And re-paint it
Old Feb 13, 2008 | 04:06 PM
gsr dood's Avatar
Default Re: Does anyone know how to remove this? (aNDrewCivcDx)
i would use some chemical paint remover......prime....paint
Old Feb 13, 2008 | 04:12 PM
usdmblackcivic's Avatar
sand the hood down with 320....prime it with a 2k primer...then sand that down with 800...now ur ready to paint..
Old Feb 13, 2008 | 04:15 PM
Default Re: (usdmblackcivic)
Is it hard to re-pain the hood by yourself? I can do all the prep work, but I think it takes some skills to paint it black again.
Old Feb 13, 2008 | 05:19 PM
Pockets's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmblackcivic &raquo;</TD></TR><TR><TD CLASS="quote">sand the hood down with 320....prime it with a 2k primer...then sand that down with 800...now ur ready to paint..</TD></TR></TABLE>
don't start with 320 it will take you ages. chemicals are your best bet that's a lot of sanding to do when you can let it set and pressure wash it off. and i wouldn't sand primer with 800 either that would also take your forever, 800 is more for panel prepping and light use on runs or sags. if there's no body work and the panel is straight you wouldn't even need to prime it at all just etch your bare metal (a wash primer sprayable from a gun for such a large area) and from there you could wet on wet it. if you do end up priming it wet block it down with 600 then go over it by hand (little circles) to make sure all your blocking marks are out. good luck.
Old Feb 13, 2008 | 10:23 PM
Default Re: (Pockets)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pockets &raquo;</TD></TR><TR><TD CLASS="quote">
don't start with 320 it will take you ages. chemicals are your best bet that's a lot of sanding to do when you can let it set and pressure wash it off. and i wouldn't sand primer with 800 either that would also take your forever, 800 is more for panel prepping and light use on runs or sags. if there's no body work and the panel is straight you wouldn't even need to prime it at all just etch your bare metal (a wash primer sprayable from a gun for such a large area) and from there you could wet on wet it. if you do end up priming it wet block it down with 600 then go over it by hand (little circles) to make sure all your blocking marks are out. good luck.</TD></TR></TABLE>
Thanks!
I'll try this weekend.
Old Feb 14, 2008 | 09:37 PM
Pockets's Avatar
good luck. if you get stuck just bump this thread w/questions.
BB1LOViN
Paint and Body
12
Dec 25, 2007 04:19 PM
sleepingeg6
Nov 28, 2005 08:54 PM
pphan3
Mar 9, 2004 05:24 PM
Goinfasterthanu
Aug 12, 2003 03:49 PM
TurboEg
Jul 26, 2003 05:12 PM
