Best cheap spray gun/s
Iv done plenty of body work and a little paint it the past but but was always with some one that had guns on hand
what im looking for is a gun or guns to paint my engine bay, i just dont want to brake the bank since they probly wont be used after this project,
i need something that i can lay down a sealer, primer, base and clear
so what do you guys recomend that wont brake the bank.
Re: Best cheap spray gun/s
Go to your local automotive paint supplier and tell them you want an astro brand paint gun or finishline which is made by devilbiss and if your wanting to use one gun make sure you get a 1.4 fluid tip the reason I say a 1.4 because you need it for the primer and when its time to seal,base,and clear you can adjust the fluid control **** right behind the needle to slow the amount of fluid down
i just orderd Devilbiss #802343 kit
not from this site but same kit
http://www.summitracing.com/parts/DVR-802343/
Good choice bro that's a perfect starter gun ,that exactly what I started with, get a couple under your belt then move on to the top dog "SATA" and then you will really enjoy spraying
I have a Devilbiss GTI for only $210shipped. Comes with 3 tips and I've only used it for about a month and has been sitting for about 4 months, cause I much rather use my SATA instead. The gun still sprays like new, so if you're interested, just PM me and let me know
