another-- help choosing an air compressor thread---
Old Oct 6, 2008 | 12:51 PM
starbai's Avatar
Default another-- help choosing an air compressor thread---
Well guys I've been doing some research on compressors and have been learning little by little as I go.
I've been wanting a compressor in my garage for some time now just for air tools and other odd jobs around the house.
But I've been toying with the idea of painting my 92 prelude myself and as a result I'm considering getting a compressor that will allow me to use it for this as well.
The thing is I know i need a big tank, but at the same time I want this to be able to be moveable and to fit in my family's Mazda6 in case I need to move it.
I would think that would limit to me to about a 20 gallon tank. Most paint guns I noticed wants about a 30gallon tank to run properly.
So I guess my question is, how negatively would a 20gallon tank affect me? What other minimum specs can I assume?
I wanted to stick to about 400 or less (just for the compressor).
I also gotta find one that doesn't require a special breaker or other type of electrical work done to my house. Its an older home and I really dont want to have to get an electrcian over since its a flat roof and I have no crawl space or any way to really wire anything up without opening up several walls.
I'd really appreciate the help and will have some more questions I'm sure as I narrow down the brand/model/specs that will suit my needs.
Old Oct 6, 2008 | 01:28 PM
starbai's Avatar
I was looking at something like this:
http://www.sears.com/shc/s/p_1...mv=rr
but i'm concerned that the sCFM is too low?
7.4 @40psi
and 5.8 @ 90psi
Old Oct 6, 2008 | 04:30 PM
starbai's Avatar
anyone?
Old Oct 6, 2008 | 05:54 PM
tony413's Avatar
im in the same boat but i dont care about tank size i just want a minium of 10 cfm @ 90psi
so im looking at this http://www.northerntool.com/we...65168
Old Oct 6, 2008 | 06:08 PM
starbai's Avatar
isn't tank size important when spraying a car tho?
if you gotta stop in the middle of a sweep for the motor to generate more pressure, isn't that a big problem?
the one you posted is great, but even if i were to give up the need for portability, what about the fact that its 230 volt?
maybe in your home that'll be fine but in mine its gonna suck. I dont know if i could even get that kinda work done without spending an arm and a leg.
Old Oct 6, 2008 | 06:25 PM
tony413's Avatar
Default Re: (starbai)
yes tank size is important but so is the HP of the pump. having a larger tank sizes helps you create that 10 cfm @ a given pressure.
here read my other thread about compressor voltage https://honda-tech.com/zerothread?id=2400752
oh yeah if i need to move the tank i can put it on a piece of wood with casters and roll it around
Old Oct 6, 2008 | 07:14 PM
crxnightrider's Avatar
that is a great compressor! not so much noise. and thats more then enuff for sprayin a car. the compressor never gets close to empty becuz its always refills way before its empty. and it most likly goin to power all ur tools. auto tools that is.
Default Re: (crxnightrider)
plus its a craftsman lifetime warranty!
Old Oct 6, 2008 | 09:01 PM
starbai's Avatar
but is it enough to power a good paint gun and do a good job on a car?
Old Oct 6, 2008 | 10:31 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starbai &raquo;</TD></TR><TR><TD CLASS="quote">but is it enough to power a good paint gun and do a good job on a car? </TD></TR></TABLE>
Look at some paint guns and check out their CFM ratings. You will need a big compressor to paint cars.
I'm also working on painting a 4th gen Prelude
Old Oct 7, 2008 | 06:56 AM
starbai's Avatar
i'm starting to realize that a small compressor is just not gonna cut it.
but it also looks like large compressors aren't capable of being run off of 120volt.
do i have any options other than doing the electrical work in my house?
Old Oct 7, 2008 | 08:45 AM
tony413's Avatar
did you read my link, it explains how you can run 240volt in a 120 volt house. also a good compressor to run a good paint gun needs ATLEAST 8 scfm @ 90psi.
Old Oct 7, 2008 | 09:13 AM
starbai's Avatar
i read it but i dont really understand what they're talking about.
I'll ask for clarifcation in that thread.
Kevs02Accord
Paint and Body
17
Nov 15, 2011 08:39 AM
blaze.1
Paint and Body
Feb 26, 2009 07:16 PM
Civic-Kids
Paint and Body
Apr 24, 2007 05:38 PM
sappsycho
Mar 23, 2003 06:28 AM
xcivicdx
Feb 6, 2003 06:59 AM
