air compressor hp question
Old Feb 23, 2009 | 01:54 PM
blaze.1's Avatar
Default air compressor hp question
i have a generalized question. what size air compressor will i need to purchase just to be used for personal use. the main use of the compresror will be running small air tools and a paint gun. what hp should i look for, what size air tank, and how improtant is cfm? i'm looking at a craftsman 1.6 hp 33 gallon tank.........
Old Feb 23, 2009 | 09:38 PM
{AJ}'s Avatar
Default Re: air compressor hp question
Not sure about everything but I've read cfm is the most important to look for. 33 gallons sounds ok to me but I'm not an expert and bigger is probably better.
Old Feb 24, 2009 | 03:04 PM
Hondauncle's Avatar
CFM is the most important rating. That air compressor is small to paint a car with, but you can get by with it. It would help if you used a conventional gun or a lvlp gun. It is definitly too small for a DA sander. I painted three cars with a 2hp, 30 gallon tank compressor.
Old Feb 25, 2009 | 05:22 PM
precisionsc54's Avatar
get the biggest comp you can afford. It will be the best advice you ever get
Old Feb 26, 2009 | 07:16 PM
SOHCunderdog's Avatar
I think that 1.6hp motor is going to stall you. With a sizeable tank like that, that motor is gonna work pretty hard to pressurize it.
Try maybe between a 3hp and 5hp.
Also make sure you put that thing where its convenient as you will have popeye arms moving it around all the time.
starbai
Paint and Body
12
Oct 7, 2008 09:13 AM
JDMDC2BOY12
Paint and Body
May 1, 2008 08:57 PM
Civic-Kids
Paint and Body
Sep 16, 2007 10:00 PM
sappsycho
Mar 23, 2003 06:28 AM
xcivicdx
Feb 6, 2003 06:59 AM
