Is 800grit to fine before i start painting my lip?
Old Aug 5, 2007 | 01:19 AM
ziptie's Avatar
Default Is 800grit to fine before i start painting my lip?
It was painted flat black, i wet-sanded it- 400/600/800. just cleaned/dried it.
is 800 to fine for the paint to stick?
do i need prep wipes before i paint?
do i need to wet-sand after it dries? if so what grit?
using automotive touch up spray paint. supposed to be pretty close to oem...
Old Aug 5, 2007 | 12:26 PM
zoso's Avatar
Default Re: Is 800grit to fine before i start painting my lip? (zunt)
I did my front grill i used 400 and 600, turned out looking good. I will only do self paint jobs for small things on my car mainly on the bottom, lip, skirtks... it doesnt look bad, it just doesnt have a refletion and shin that paint shops can get you!
Old Aug 5, 2007 | 12:50 PM
jakeiscool's Avatar
Banned
youd be better off with something less abrasive because if the lip is abs, once you sand down through all the paint then youll start sanding the plastic and youll see that it just sort of melts rather than scratching up like paint would.
Old Aug 5, 2007 | 03:35 PM
ziptie's Avatar
its an oem lip
Old Aug 5, 2007 | 06:03 PM
johnxboi's Avatar
it really isnt necessary to go through all those grits, 800 is okay for paint to stick. most body shops and myself personally i prep the surface with 600 before i paint.
Old Aug 5, 2007 | 06:52 PM
ziptie's Avatar
Default Re: Is 800grit to fine before i start painting my lip? (johnxboi)
whats the difference in the finished product if you prep it with 600 vs 800
Old Aug 5, 2007 | 08:15 PM
shad0wslay3r's Avatar
adhesion
Old Aug 6, 2007 | 05:30 AM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zunt &raquo;</TD></TR><TR><TD CLASS="quote">whats the difference in the finished product if you prep it with 600 vs 800</TD></TR></TABLE>
No difference. As long as you scuff the plastic it will give the paint something to stick too. It's also wise to use an adhesion promoter, an adhesion promoter should always be used on raw plastic.
You don't have to do steps in grit when scuffing the plastic. You could have just used 400, or 600, or 800 etc... You could have also scuffed it with a 3M scuff pad and sanding paste.
Old Aug 6, 2007 | 08:09 AM
ziptie's Avatar
Default Re: Is 800grit to fine before i start painting my lip? (WihaSi)
where can i get adhesion promoter? brand?
Zaraki
Paint and Body
May 21, 2008 03:24 PM
em1tuner
Honda Civic (2001 - 2005)
May 15, 2007 09:12 PM
07rebel
May 8, 2007 03:06 PM
DC5StylZ
Aug 3, 2006 07:10 PM
pgFA
Mar 3, 2006 08:39 PM
