Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
ATF
Old 09-21-2017, 12:09 PM
CRP
CRP's Avatar
Default ATF
I have an 03 Pilot. Whats a good replacement for Honda ATF Z1
Old 09-21-2017, 01:09 PM
Global Moderator
tech8's Avatar
Default Re: ATF
Honda ATF DW-1.
Old 09-21-2017, 01:34 PM
CRP
CRP's Avatar
Default Re: ATF
I quess I should have been more clear.....aftermarket ATF
Old 09-22-2017, 10:38 AM
speedlever's Avatar
Default Re: ATF
I believe the 2003 Pilot uses tranny fluid to lube both the transmission and the transfer assembly. They were separated in 2006 and the TA is now lubed by hypoid gear oil. That being said, I do not know the fluid capacity of the 2003-2005 Pilot automatic tranny. If it's the same as the 2006 and on, then the following should be very close..
I would be very hesitant to use anything other than Honda fluid. Is there any real cost advantage in doing so? And if the '03-'05 models are like 2006 and on, you'll need to do at least 4 drain and fill operations (with some driving in between exercising all gears including reverse) to effect a change over to the new fluid. If the fluid capacity is 8.5 US quarts and if you drain and fill 3.5 US quarts, then 4 d&f operations will get you to about 88% DW-1 as you can see by the chart.
Of course this warning was issued prior to the release of DW-1 which is a direct replacement for ATF Z-1:
Old 09-23-2017, 12:59 AM
Sanji
toyomatt84's Avatar
Default Re: ATF
Its unwise to use aftermarket options, as they aren't designed to the same specifications as the Honda fluid. What's your reservation with using Honda fluids?
Old 10-24-2017, 10:53 PM
Spudz76's Avatar
Default Re: ATF
Another very emphatic vote for DW1 only only only.
DO not listen to anyone running other fluids, they are either LUCKY or just haven't destroyed their trans yet.
Valvoline MaxLife Synthetic is pretty close to Z1. But DW1 is unicorn blood, has a purple hue and is thinner/flows easier, smells funny. Definitely not like ANY other fluid I've ever seen, and it is magical in Honda transes.
Old 10-26-2017, 02:01 PM
jekmandco's Avatar
Default Re: ATF
Im assuming the DW1 can also be used in the '06 Odyssey Trans? I think the book said to use the Z1 in the Odyssey.
Old 10-26-2017, 02:13 PM
Global Moderator
tech8's Avatar
Default Re: ATF
Z1 is no longer made. Yes, DW-1 is completely compatible and a better fluid.
Old 11-05-2017, 01:06 PM
frostwhite_92's Avatar
Default Re: ATF
Red Line D4 or D6.
I use D4 in my Odyssey and my TL and D6 in my wife's '12 Pilot.
quiet4no1
04-02-2009 10:59 AM
djviet2000
12
06-14-2007 10:54 AM
mysicivic1991
04-16-2007 09:53 AM
globy123
12-17-2006 07:20 PM
Brolli007
12-22-2002 12:09 PM
Quick Reply: ATF
