FS. 1997 Integra GSR Turbo
Old 06-25-2011, 10:01 AM
cquence's Avatar
Icon5 FS. 1997 Integra GSR Turbo Price Drop $8000
Vehicle: Integra GSR
Year: 1997
Mileage: 144,097
ASKING PRICE: $8200. CLEAN TITLE Price drop from $9000
Well its finally time to put my Integra up for sale. Its been a good fun little car that has served me well. Since this is not my daily driver the car rarely gets driven. Its only reserved during dry and sunny weather and has not seen rain since it was retired from a daily driver back in 2007. Its probably better off to someone who will enjoy it more frequently. As a former factory trained Honda Technician, I performed most of the maintenance and work that was involved using the factory manuals. I also hold the all the maintenance records from the previous owner which were all done at the dealer. I only used the best quality parts as you can see in the mod list and the car is tastefully put together.
The turbo setup only has about 3,000 miles since 2008 and the new clutch and LSD have about 500 miles total since 2010. The car was tuned at SpeedFactory by James in Tacoma, WA. It made 362whp at 10.5psi on their Dynopack Dyno. The car starts up, idles, and drives like a factory Integra and very easy but fun car to drive. Im only selling this car because my interest into the Honda scene has changed but I am not desperate. The car is very well documented so If there is something you would like to know or see, I have over 500 pictures of the car since aquired.
NO TRADES and NO Parting out.. Please
My Build tread on Team-Integra Back in 2008:
http://www.team-integra.net/forum/16...d-project.html
Turbo Startup video 01-13-08
Check out the odometer when the camera zooms in. The car only accumulated 2863 miles since I posted this video lol.
SpeedFactory Dyno tune Video
New Walk around Video 7-28-11
New inside view Video 7-28-11
Engine
-100% stock B18C1 engine
-Skunk2 Pro Intake Manifold
-Hondata Thermal IM gasket
-Omni-power 4Bar Map sensor
-RS Machine Thermal TB gasket
-Billet Innovate engine mounts 75a rating
Transmission:
-Quaife ATB Helical LSD
-Carrier bearings switched to roller bearings
-Replaced input shaft bearing
-New ring gear bolts used for install
-Resurfaced OEM GSR flywheel
-Clutch Master FX400 kit
Fuel Delivery:
-Walbro 255LPH fuel pump
-RC Engineering 650cc Saturated injectors
-OBD1 Injector clips rewired in
-Mashall Fuel pressure guage
Engine Management:
-OBDI P75 converted to P72 Specs vtec ECU by Xenoncron.com
-Moates Demon installed inside the ECU
-OB1 to OBD2 conversion harness
-Innovate Motorsports LC-1 wideband sensor/controler
-Innovate Motorsports XD-16 wideband gauge
-Neptune RTP Tuned by James of SpeedFactory
Force Induction Kit:
-PeakBoost Ramhorn Stainless Steel equal length exhaust manifold
-Garrett T3/TO4E turbocharger
-Tial 38mm wastegate
-PeakBoost(Garrett core)24x6x3.5 Intercooler
-Tial 50mm blow off valve
-2.5in intercooler pipes
-3inch downpipe with stainless flex section and wastegate dumptube.
-Hallman MBC
Engine Cooling:
-RS Machine Dual Core all aluminum 1/2 size radiator
-13inch SPAL radiator fan
-Custom aluminum radiator shroud made by Joe from Tempest Racing
Exhaust:
-3" Thermal Research System
-3” testpipe
Wheels:
-15x9 Kosei K1 wheels
-215/50/15 BFgoodrich G-Force Sport Tires
Suspension:
-Koni RED adjustable Shocks
-Omni-Power Sleeve coilovers
-Skunk2 front camber Kit
-Rear Camber kit
-Comptech Sports adjustable rear Swaybar/Tie bar Combo (discontinued)
Exterior:
-98+ OEM Front Bumper
-98+ OEM front headlights
-98+ OEM Type R front lip
-98+ OEM Rear Bumper included (not installed)
-98+ Type R wing
Interior:
-4 POD bezel
-Prosports Peak and Warn Oil Pressure guage
-Prosports Peak and Warn Fuel Pressure guage
-Prosports Peak and Warn Boost/Vac guage
-Authentic MOMO 350mm Competition steering wheel
-OEM Honda Fit Billet 5spd shift ****
[IMGhttp://farm7.static.flickr.com/6141/5935518261_086c7dbf73_z.jpg][/IMG]
cquence is offline
Old 06-25-2011, 09:44 PM
cquence's Avatar
Default Re: FS. 1997 Integra GSR Turbo
Video links added on first page!!
cquence is offline
Old 06-26-2011, 03:50 PM
cquence's Avatar
bump
cquence is offline
Old 06-28-2011, 06:36 AM
cquence's Avatar
bump
cquence is offline
Old 06-28-2011, 11:07 AM
FULLYBUILT2.0's Avatar
Very clean GLWS
FULLYBUILT2.0 is offline
Old 07-01-2011, 01:39 PM
cquence's Avatar
Originally Posted by FULLYBUILT2.0
Very clean GLWS
Thanks man..
cquence is offline
Old 07-02-2011, 04:47 PM
cquence's Avatar
Saturday Bump
cquence is offline
Old 07-02-2011, 05:57 PM
jasoncrashtech's Avatar
pm'd and bump
jasoncrashtech is offline
Old 07-03-2011, 09:11 PM
cquence's Avatar
Sunday Bump
cquence is offline
Old 07-04-2011, 10:48 PM
cquence's Avatar
4th of July Bump
cquence is offline
Old 07-10-2011, 08:05 AM
cquence's Avatar
Sunday Bump
cquence is offline
Old 07-13-2011, 08:55 PM
cquence's Avatar
New Pictures *FIXED*
cquence is offline
Old 07-15-2011, 05:06 AM
vipersal's Avatar
so clean
bump
vipersal is offline
Old 07-16-2011, 02:41 PM
cquence's Avatar
Originally Posted by vipersal
so clean
bump
Thanks man...
cquence is offline
Old 07-19-2011, 10:37 PM
shadohconspiracy's Avatar
bump for a clean *** integra and for installing my comcast!
shadohconspiracy is offline
Old 07-23-2011, 11:39 PM
cquence's Avatar
Thanks man. Enjoy your Comcast internet. Nice GTI too, those SSR rims are sick
cquence is offline
Old 07-28-2011, 09:06 PM
cquence's Avatar
New vids posted..
cquence is offline
Old 07-28-2011, 09:21 PM
cquence's Avatar
and a Price drop Firm though
cquence is offline
Old 08-10-2011, 07:38 AM
cquence's Avatar
bump
cquence is offline
Old 08-14-2011, 09:51 AM
Hiii Im TYLER's Avatar
So does the car still have excessive blow-by?
Hiii Im TYLER is offline
Old 08-14-2011, 12:54 PM
cquence's Avatar
No the excessive oil that was coming from the turbo was not due to blow-by or inadequate return line. Peakboost some how supplied me a -4AN oil feed line instead of a -3AN. I bought a new oil feed line and problem solved no more smokey tail pipe.
cquence is offline
WannaRun??
04-20-2015 05:11 PM
GSR_FTW
Northern California (Sales)
03-27-2015 07:13 PM
rOby
02-23-2013 07:19 AM
cquence
08-14-2011 05:13 PM
stupidwhitecat
08-21-2007 06:53 PM
Quick Reply: FS. 1997 Integra GSR Turbo
