civic, integta, b series, turbo parts
Old 01-04-2015, 09:09 AM
sean082's Avatar
Default civic, integta, b series, turbo parts
I have extra parts laying around collecting dust. Looking for cash only, only trade would be for a D16Y8 long block in good running condition. No junk.
Located in the Puyallup/Tacoma/some times kent areas. Local pick up only. Thanks
253 241 9693
Honda p74 hg $50 bnib
Honda p74 tbelt tensioner $40 bnib
Honda p74 valve cover set $20 bnib
felpro LS ALT belt $10 bnib
flepro LS PS belt $10 bnib
flepro LS AC belt $10 bnib
Honda P72 oil pump $100 bnib
flepro b series cam seal $10 bnib
d16y7 valve cover set $10 bnib
YEC b series vtec obd1 cap & rotor $40 bnib
NSK front wheel bearing 92-00 civic ex $40 bnib
P30 cam seal $10 bnib
ARP b series crank pulley $15 bnib
Stone P72 gsr complete HG set $100 bnib
Hastings 81mm b series piston rings $50 bnib
NGK 7 plugs (4) $15 bnib
NGK 6 plugs (4) $15 bnib
integra oem shifter/**** $30
civic integra obd1 main fuel relays $15 ea. in good working condition
bare P73 type r intake mani $60
B series trans spool w/ new bearings and gsr/b16 final $220
gsr hydro transmission $450, in good working condtion
integra / civic walbro 255 $50 in good working condition
golden eagle main girdle b series was slight damage but doesn't effect functionality at all. $50 in good working condtion
godspeed 57trim turbo $120 new never used T3 flange
B series block guard $20 bnib, not sure on brand
SF air cone w/ coupler $10
autometer 5" tach 10k rpm $20 in good working condition
P06 obd1 civic ecu (manual) $40
P2N obd2 civic ecu (manual) $40
b series obd1 vtec msd ignition set up $220
diz, cap, rotor, digital 6 box, ngk wires, blaster coil, wiring
blox manual boost controller $40, in good working condition
4 x 100 15" wheels w/ 195/50 all matching tires 70% tread $200
no issues all hold air, no bend or cracks, just an extra set laying around.
P72 gsr head fully port and polished. was on my turbo civic couldn't figure out my oil burning issue. long story short this head will need new guilds installed. Port work cost ne $1000 alone at ASP. If you are serious about the head I can give you the complete story. I will write bill of sale for this. $500
sean082 is offline
khaledbuiltEF
10-18-2012 12:50 PM
dizzyroc88
Southeast (Sales)
03-13-2006 06:33 PM
dizzyroc88
03-08-2006 05:15 AM
dizzyroc88
03-08-2006 05:14 AM
Quick Reply: civic, integta, b series, turbo parts
