Ignitors, tires, distributor parts, 3 Spoke steering wheel, Free stuff, CHEAP!! SF
2 Coil/Ignitors for d16a6 SI or D15 for HF CRX/Civic CHEAP!! SF
--I have two perfectly good working coils that came out some dizzys/distributors with bad bearings.
$20 each or $30 for both. SAVE these are $65-100 normally.
---Also, two good distributor caps. Both in like-new condition. $5 each
---Good used set of spark plug wires $5
---FREE 2 distributors. One with bad bearings and one with a bad cyl sensor. The plugs are good on them...FREE
--- 3 Spoke CRX/Cvic Si steering wheel. The cover is broken off but if glued down will look perfect. $5
---Good Used Tires!! If you take all of them you can have them for $20!!
NEW!!! Doral SDL 185/60/14 99% tread. Only used a few hundred miles. $15
Goodyear GT HR 195/60/14 50% tread Has a patch from previous puncture (I never knew till I took it off, holds air perfectly fine). $5
Federal Super Steel 195/60/14 has a nail in it, but has around 70% tread...Six pack of Bud Light or Free!!
Negotiator 195/60/14 90% tread $15
TAKE EVERYTHING FOR $60!!
Thanks
The tire on the bottom has 99% tread:
Modified by wakaranai at 2:52 PM 1/22/2008
Thanks
10cjennings
01-15-2013 11:37 AM
mtny
Southeast (Sales)
17
05-21-2009 11:53 AM
ElementMotor
16
07-18-2003 01:17 PM
