b20vtec partout&jdm civic integra misc.......
94 ls long block has low compresion on #3 cyl needs rebuilt $200
gsr injectors $40
b20 crankshaft already micro polish $150
stock gsr rods w/ycp high comp. piston standard $150
0bd1 p75 ecu chip $120
2 obd0 pr4 ecu $50 ea.
LS SLEEVED BLOCK 86MM BUT U HAVE TO GO 86.5MM COMES WITH Z10 GIRDLE ASKING $450
gsr str intake manifold $200
obd1 ls engine harness $100
stock gsr camshaft $50
obd1 ls distributor $120
stock gsr springs and retainers $50
stock type r dual valve spring $120 soldddddddddddddddd
90-93 INTEGRA HALFSHAFT $50
d series lightweight flywheel $50 soldddddddddddddd
eg6 jdm power folding mirror complete w/ relay and switch $200
eg6 jdm doors white comes w/ power window/ no glass or panel $150
jdm bumper pole comes w/ switch $180
b20 vtec specs
gsr head p&p by dave @dnr $800 THATS JUST FOR THE P&P the price is for the head only.. comes w/ valves and stock gsr spring and retainers already tapped solddddddddddddddddd
sk2st2 cams w/ blox cam gears $500
blox dual valve spring & retainers $200 cams ,camgear and springs retainers $600
vistor x manifold/blox 70mm tb $500 obo port match w/tb 70mm
aem fuelrail/rc 310cc/ $300
ssr side exit $700
msd 6al /msd blater coil $300 comes w/ distributor
valve cover breather kit comes w/ valve cover brand new $250
golden eagle vtec conversion $200 almost brand new
b series shift linkage comes $50 solddddddddddddddd
b20z block bored 85mm
blox magnetic drain plug
new oem water pump
new oem seals
stock ls rods w/ ard rod bolts
rs machine type r
micropolish crank
oem bearings
type r oil pump
COMPLETE SHORTBLOCK $1300 100% NO PROBLEM
type r tranny 4.4 fd $1200 asking $900 100% no problem soldddddddddddddddddddddd
stg 2 exedy 3 puck $480 brand new asking $200 solddddddddddddddddddd
toda light flywheel $250
tuned by dave @dnr
p28 s200 hondata $300
made 236hp 154trq
ran 11.8 qtr mile @112 mph
1.6 60ft
used about 1200 miles so far
if interested call me at 5103143032 name is ryan thanks
email me for pics
gsr injectors $40
b20 vtec specs
ssr side exit $700
new oem water pump
new oem seals
rs machine type r
micropolish crank
oem bearings
type r oil pump
tuned by dave @dnr
made 236hp 154trq
1.6 60ft
email me for pics
Re: b20vtec partout&jdm civic integra misc.......
i will let u know if the guy will buy my head dont need the vtec solenoid u will find out from me on monday
lakaspeed
Northern California (Sales)
06-12-2009 02:07 PM
lakaspeed
09-17-2008 09:04 PM
