B18C1 Short Block Fresh Build JE 10:5:1 Pistons Ready to Go!!
UPDATE: SOLD as of 12/23/2008!
UPDATE: B18C1 Long Block Fresh Bottom Build JE 10:5:1 Pistons Ready to Go!!
<u>ZERO MILES ON SHORT BLOCK ASSEMBLY!!!</u>
$2500.00 FIRM (includes Head, Block, Tranny, Clutch; everything pictured)
This is a freshly built complete B18C1 short block. All parts are brand new. Professionally assembled by TrackSpeedRacing. Would be perfect for anyone looking to run a mild all motor street setup. 190+whp easy with bolt-ons, headwork, and a good tune. Call (925) 354-6439 if you're interested in purchasing this block. The following has been done:
BOTTOM END SPECIFICATIONS:
Inspected
Hot Tanked
Honed
Decked (.003")
Resurfaced Flywheel
Micropolished Crank
Balanced Bottom End
Ring Gap Clearance Set
JE 10:5:1 Pistons (81.00mm standard)
JE Piston Rings
ACL Standard Bearings
Stock B18C1 Rods
ARP Headstuds
OEM Acura Water Pump
OEM Acura Oil Pump
OEM Acura Rear Main Seal
OEM Acura Oil Pan Gasket
OEM Acura Headgasket
OEM Timing Belt
Cleaned Oil Pan
Evolution Industries Crank Pulley
TOP END SPECIFICATIONS:
Stock Unported P72 GSR Head
Hot Tanked
Pressure Tested
Vacuum Tested
Resurfaced
OEM Acura Valveseals (brand new)
OBD2A GSR Intake Manifold
VTEC Solenoid
All Cylinder Head Sensors
IACV
OEM Acura GSR Camshafts
Rocker Arm Assembly
Cam Plate Cap Covers
Evolution Industries Cam Seal (brand new)
Black OEM Valvecover
Tri-Y 4-2-1 2.5" collector header (brand new)
DRIVETRAIN SPECIFICATIONS:
S80 5spd B18C1 Tranny (guaranteed to shift perfect!)
Action Clutch 1MS Kit (brand new)
Resurfaced B18C1 GSR OEM Flywheel
Inspected
Hot Tanked
Honed
Decked (.003")
Resurfaced Flywheel
Micropolished Crank
Balanced Bottom End
JE Piston Rings
Stock B18C1 Rods
ARP Headstuds
OEM Acura Oil Pump
OEM Timing Belt
Cleaned Oil Pan
Hot Tanked
Pressure Tested
Vacuum Tested
Resurfaced
VTEC Solenoid
IACV
Rocker Arm Assembly
boosted hybrid
09-10-2003 12:16 PM
