Semi Built Lsvtec!!!
Old May 21, 2009 | 10:31 PM
dntbh8n's Avatar
Default Semi Built Lsvtec!!!
What's Good? Selling My Swap With 0 Miles!!! I Think I wanna Go Boost! Theres No Set Price As Of Yet But I Do Know What I Have Into It And Not Going To Take A Big Loss At All!! So If U Looking For A $1800 Swap This Post Isnt For You. Trying To Go Boost!!! Please Dont Pm Posting For A Friend Contact Info Bottom Of Page!!!!
Seriel Number- 2357515
*Block-
B18a1
Sandblasted And Painted Silver
Decked And Honed
81mm
Polished Crank
Acl Rod And Crank Bearings
Arp Head Studs
Arp Rod Bolts
New Front And Rear Seals
New Oil Pan Gasket
New Headgasket
Gsr Water Pump
Type r Oil Pump
Oem Timing Belt
Ctr Pistons
Shotpeened Ls Rods
New Hastings Piston Rings
Cusco Super Single Clutch
*Head
Pr3-2
BuddyClub Stage 3 Cams W/ Sk2 Cam Gears
Sk2 Springs And Retainers
Kms Flat Valves
Mild Port Polish
New Valve Seals
New Intake and Exhaust Gaskets
Sk2 Intake Mani
Golden Eagle Fuel Rail
Type R Vtec S.
All Seals Gaskets Are New All Sensors Are In Working Condition!
*Misc
Hydro Gsr Trans
Itr Shift Linkage
Obd 2a Gsr Ecu
Odb1 P28 W/Stepdown
Earls Line And Fittings
Gsr Axles
Halfshaft
Obd2a Harness
Golden Eagle Dowel Pins
*I Know Im Forgeting **** Will Update!!!!
*Motor Will Be Assembled Within The Next 2-3 Dayz!!!
*This Is Going To Be A Full Swap With Ac And Power Steering All Accs!!!!
Contact Info
(Cell) 845 633 9498
(Aim) Hovathagod97
Your Name
233
Mar 12, 2014 02:45 PM
Shane_00integra
Sep 19, 2012 01:44 PM
x still jaded x
Sep 7, 2010 05:19 PM
B18C5civic
Mar 14, 2006 10:46 AM
synergy004
Dec 18, 2002 01:41 AM
