Pa-fs/ft 94 integra gsr 2.1L all motor
for sale or trade is my 1994 acura integra gsr. 190xxx on the body about 55000 on motor and 30000 on the trans. the price is obo but i would like to trade for a eg hatch, em1, stock integra, 240sx or maybe a streetbike 600cc and up. the car is inspected for almost a year. makes 215hp to the wheels on 93. tuned by steve @ romisburning fast as or faster then a k20. its my daily driver and is very reliable. has very little rust that is only on the surface. hardly noticeable. has full wire tuck with relocated fusebox and battery. new oddysey pc680 battery no ac but has ps. converted to non abs using all oem lines and prop valve. i tried to list everything i could and i know im forgeting a couple things.i have receipts for almost everything. im looking to get 5800 but throw me some offers. call or txt me at 610 952 8845 if your interested.
exterior
oem mud flaps
si vtec lip
amber corners
wingless
new oem badges
interior
autometer oil pressure and water temp gauges
kenwood headunit and speakers
new trunk carpet
wink mirror
oem ac delete duct
oem itr shift ****
suspension
koni race yellows
eibach springs in front and h&r in back.(nice stance and ride)
megan lca
ebay tie bar
itr rear sway bar.(not installed)
oem strut bar
misc. new bushings
wheels/tires
buddyclub p1 sf 15x6.5
dunlop direzza dz101 less then 5k miles on them
skunk2 lugnuts
motor/drivetrain
built gsr motor
type r cams
type r valve springs
type r retainers
gutted stock manifold
whale ***** intake
precison 440cc injectors
255 hp warlboro fuel pump
arp head studs
golden eagle head gasket
timing belt changed 20,000 miles ago
new water pump
new thermostat+coolant
86mm golden eagle sleeved block
12:1 COMPRESSION
wiseco forged pistons
eagle forged rods
micro polished 89mm b18 crank
acl race bearings
all arp hardware
moroso 5 quart oil pan with extended moroso oil pickup
moroso vented oil catch can breather tank with custom extra baffles from a machine shop!
REAL sms product tri-y headers big tube. they retail for 1300
thermal r&d 2.5 inch exhaust
competition stage 4 clutch 6 puck unsprung
9 lb. fidanza flywheel with arp flywheel bolts
b16 1-4 ls 5th
itr 4.78fd
phantom grip lsd
all new synchros and bearings about 30000 miles ago
5th gear was done at imw in carlise pa
also had trans cleaned and inspected
the bad
needs alignment
carpet is dirty
could use some bodywork
needs starter signal switch. I am ordering that this week and installing it soon.
pics can be seen here
http://philadelphia.craigslist.org/cto/2516632750.html
exterior
oem mud flaps
si vtec lip
amber corners
wingless
new oem badges
interior
new trunk carpet
wink mirror
oem ac delete duct
oem itr shift ****
suspension
koni race yellows
megan lca
ebay tie bar
oem strut bar
misc. new bushings
wheels/tires
skunk2 lugnuts
motor/drivetrain
built gsr motor
type r cams
type r retainers
whale ***** intake
arp head studs
new water pump
12:1 COMPRESSION
eagle forged rods
acl race bearings
all arp hardware
b16 1-4 ls 5th
itr 4.78fd
phantom grip lsd
the bad
needs alignment
carpet is dirty
Re: Pa-fs/ft 94 integra gsr 2.1L all motor
here is a video my friend took. open header on nitto drag radials
http://www.youtube.com/watch?v=gIZDMSnzPTA
dustinbs144
Northeast (Sales)
01-19-2011 03:28 PM
