FS:PA obd1 ls longblock, y8 intake maniold and more
FS:central pa honda,acura sale
im located in central PA.
first up for sale is a obd1 ls long block including the ecu. the motor is very well taken care of. i also did a compression test and it is 180-185 accross all the cylinders. all the gaskets were replaced including the whole pcv system because it was leaking out of there. the oil was changed every 2500-2800 miles with moble 1 synthetic 10w40 and used a hamp oil filter. it has a powdered coated red vavle cover. the motor was reaplced in my car when i got it so the milage of the engine is unknown but my odometer reads 194611. i would put my guess of around 110-120 on the motor. it was never redlined or beaten. very well taken care of.
here are pics of it in my integra. the motor is out of the car. i would like 500 neg
SOLD!!!!! TO "hondapimp125.
next is a d16y8 intake manifold out of a 1998 ex 5speed. so it does not have the stupid air injection and has the ports on the back for a 2wire iacv. this is a great upgrade for you d-series ownders. the manilfold was painted satin black. it comes with all new gaskets and all new bolts and a new pcv valve(everything is oem honda,still have bags for proof). even comes with all the vacume hoses you need to do aplug and play. it does NOT come with the throttle body in the picture. also comes with the d16y8 manifold bracket with new harware if you bolting it on to your d16y7 for a nice upgrade. i would like 100 plus shipping. i have over 65 dollars in gaskets and bolts included.
SOLD!!!!!! TO anthony918
next is a virgin P06 ECU. only thing i did with the ecu was i made a clear lexan cover. i will inlcude the lexan cover and the orginal cover with it. it came out of a 1994 honda civic hatchback dx 5speed. i would like 40 plus shipping.
I also have a 92-93 integra gs 5 speed ecu. its also a virgin ecu that has never been open. i would also like 40 plus shipping for the ecu.
SOLD!!!!! TO "B16RacerN2NR"
next i have for sale is a intake for a 1990-93 acura integra. it will work around your abs sytem. it will include a k&n filter. the filter has about 6000 miles on it so it will not need cleaned for awhile. i would like 45 plus shipping neg, or i will trade for a 1990-91 stock intake for a integra.
SOLD!!!!!!!!TO "coke"
next is a innercooler. it does not have a brand all it says is jdm on the top so im assuming its just an off brand. im not sure of the size. i would like 50 plus shipping neg
next is a throttle cable out of a 98 civic EX. for anyone swaping the 96-00 hatch who have that huge throttle cable and need a shorter one this is what you need or even if your doing a b-series swap in your EK hatch since the y7 throttle cable is super long. i would like 20 plus shipping.
d16y8 throttle body off of an automatic so it has the 3wire iacv on the throttle body. nothing seems to be wrong with it i just do not need it. nothing is broke. also will include the oem honda gasket with it. i would like 20 plus shipping
I have 3 oem lips and want 40 plus shipping for each one
88-89 crx si lip
90-91 integra lip
90-93 accord lip
I have a set of oem 92-93 integra rs,ls,gs mounts with brand new urathan mount inserts. i would like 65 plus shipping
Next is a crank pully off of my 92-95 b16 swap. i would like 30 plus shipping for this.
lastly is the evap parts for a 90-93 integra. it will include the charcoal canister,purge valves and the map sensor that is not pictured. i would like 20 plus shipping.
p30 b16 intake manifold. it will not come with any accessories or hardware. it was just sand blasted to be cleaned up, good upgrade to who ever has a obd0 b16intake manifold. the p30 flows more then the pr3. wat you see is what you get. 35plus shipping
i got this grill from elite imports in philly cause i thought my girls grill was broken on hers but come to find out it was not i just could not remember. i actually removed this from a purple in color ek4. i don't know if there is any difference from usdm grills and jdm. i got it for 50. i would like 25 plus shipping
i also have a armrest delete from my 98 civic dx. dark grey in color. 15plus shipping
88-89 crx si lip
90-91 integra lip
90-93 accord lip
