FA5/FG2 2006-2011 Honda Civic Si aftermarket parts
All parts came off of my 2009 Honda Civic Si sedan. All items located in Owings Mills, MD 21117 (about 50mins SW of York, PA.... Google it! Don't ask me "How far are you from xxxxxxxxx city?)
KW V3 (#35250052) coil-overs (comes with instructions, tool kit, original box, etc). Never driven during winter, less than 10k miles. Height adjustable with independent compression and rebound adjustment (minor "nicks" from height adjustment wrenches, rocks/debris/etc) -- $1375
Skunk2 4-2-1 Tri-Y Race Header -- SOLD
Set of 4x Enkei RPF1 17x8 et45 5x114 (15.6lbs each!!!) (center caps and hub-centric rings not included). Have minor scratching/wear from multiple track days and tire mounting/dismounting -- SOLD
Set of 4x Toyo RA-1 235/40-17 R-compound tires (heat cycled and shaved, 8 heat cycles) -- SOLD
1x new Toyo RA-1 235/40-17 R-compound tire (freshly shaved and heat cycled from Tire Rack) -- $160
Set of 4x BFGoodrich T/A R1 R-compound tires (heat cycled and shave, not sure of age or heat cycles; used them for auto-x for a while) -- SOLD
Set of 4x stock 2009-2011 Civic Si wheels (some are rough, some are reasonable condition; definitely not "mint" but they are straight) -- SOLD
Set of SPC rear camber arms (comes with instructions, stickers, original boxes, etc). Never driven during winter, less than 10k miles -- $180
Skunk2 Low-Profile Washer Kit (never used, comes with original box and according to instructions all hardware is present... in fact, there's extra hardware not mentioned in instructions...? Not sure why) -- $60
Exedy Racing Stage 1 Pressure Plate only from 08806 clutch kit (unused; installed clutch disc incorrectly / damaged clutch disc splines but the pressure plate is in perfect condition / I can include the clutch disc is you really want it but you'll probably have issues with engagement/disengagement). Will include inspection report from Exedy explaining damaged clutch disc -- $125
Eibach 19mm rear sway bar (never used, includes stickers, instructions and original box) - $150
Hawk DTC-60 front brake pads HB361G.622 (fit 2006-2011 Civic Si, 2000-2009 S2000 and 2002-2006 RSX-S). Includes sticker, original box and I'll throw in 1L new ATE Brake Fluid -- $150
Re: FA5/FG2 2006-2011 Honda Civic Si aftermarket parts
Update: Set of Toyo RA1 tires and BFGoodrich tires sold. One brand new, newly shaved and heat cycled Toyo RA1 remaining
Update: Skunk2 Race Header and stock 2009 Civic Si wheels sold
tamadrumr88
Mid-Atlantic (Sales)
08-19-2015 06:07 AM
