92 hatch with built motor
up for sale is my unfinished project. its a 92 dx hatch, gsr front and rear disc brake swap, i also have the front and rear sway bars, front gsr leathers rear gsr clothes, i replaced the pass rear quarter arch(needs to be puttied and smoothed), the driver side rust was cut out and filled by the previous owner of the shell, it has stock struts with what looks like tein springs(no name on them but there green), it has skunk 2 adjustable front upper control arms on it and i have brand new skunk 2 coilovers to go with the car, the wheels are si's with brand new bf goodrich g-force ta tires, 97 gsr trans with phantom grip lsd installed(no grinds or noises), the motor is a b18a1 bored to 81.25mm with srp 11.1 pistons-srp rings-eagle h-beam rods-honda rod bearings-acl main bearings-balanced crank, the head is a type-r ported with a 3 angle valve job-skunk 2 dual springs-skunk 2 titanium retainers-skunk 2 new style intake mani-stock type-r cams-skunk 2 adjustable cam gears. precision 310 injectors. mishimoto rad. cheap 4 into 1 headers. p28 ecu with hondata s200. motor was tuned and dynoed by philly dyno works. 179whp 131ft-lbs-trq. i also have a wet nx nitrous system setup in the car with a 100 shot. did not dyno on nitrous because i have not finished hooking it up to run of the hondata. nitrous was sprayed on motor while street driving though. the car needs fenders and a hood(they are there, just dinged up) i have a jdm fog light kit and type-r style front poly lip to go with it. 5k obo i have $6500into the motor and trans.http://i148.photobucket.com/al...1.jpg http://i148.photobucket.com/al...3.jpg http://i148.photobucket.com/al...6.jpg http://i148.photobucket.com/al...7.jpg http://i148.photobucket.com/al...5.jpg
Re: 92 hatch with built motor (abusedhusband)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abusedhusband »</TD></TR><TR><TD CLASS="quote">please bump if you veiw.</TD></TR></TABLE>
I viewed so I bumped.
Re: 92 hatch with built motor (FlatBrokeHatch)
you gotta be f*ckin shittin me!
you didnt even get to enjoy it since its been tuned! you drove it a total of like 10miles!!!
why the hell are you selling all your stuff when you were so close to having a bad *** whip??!!
