2000 Integra GSR transmission/ 96-99 ecu
1998 Integra LS transmission/ 96-99 ecu GSR
PLEASE DIS REGARD THE TITLE I WAS NOT AWARE UNTIL I RAN THE VIN. I BOUGHT THE SWAP UNDER THE IMPERSION IT WAS A COMPLETE GSR WITH IT BEING SO CLEAN I DIDN'T BOTHER TO CHECK IF THE VINS MATCHED CONSIDERING I ONLY NEEDED THE MOTOR.
I had this listed as a GSR and then ran the vin and found it was actually a LS transmission but the car fax showed the car having 79,365 miles on it at the time of the accident.
Vehicle:1998 ACURA INTEGRA LS
VIN:JH4DC4359WS004129
1998Acura Integra 5speed Manual LS transmission. This transmission was pulled from a rear end wrecked car, it shifts smoothly with out any issues and has under 80k miles on it. You will be recieveing the transmission only w/out the speed sensor. I want 450$ OBO
I also have a GSR P72A02 ECU from a 96-99 integra gsr 5speed-125$
You can call or text me at 267-784-9412 PLEASE LOOK UP MY LOCATION BEFORE CALLING. WHICH IS LANGHORNE PA 19047
Re: 1998 Integra LS transmission/ 96-99 ecu gsr 5spd
Just like the title says I have a mint 1998 Acura Integra 5speed Manual LS transmission. This transmission was pulled from a rear end wrecked car, it shifts smoothly with out any issues and has under 80k miles on it. You will be recieveing the transmission only w/out the speed sensor. I want 450$ OBO
I also have a GSR P72A02 ECU from a 96-99 integra gsr 5speed-125$.
socalJDMer
11-01-2010 11:01 AM
nyo91
07-19-2004 02:01 PM
