DIY BiXenon Projector Retrofit Kits, LIFETIME WARRANTY
Old 08-13-2009, 07:01 PM
retrosolutions's Avatar
Default DIY BiXenon Projector Retrofit Kits, LIFETIME WARRANTY
NEW LOWER PRICE!!!
Want a projector retrofit but don't have the budget to go all out?
Want a projector retrofit but don't have the tools, time, or know-how?
Here is an easier, less expensive option for those looking for projectors in their reflector lamps!
ORDER HERE: http://www.retrosolutionsllc.com/ser...ors/Categories
Free Shipping in the USA! - Also use HT member discount code: HONDATECH
EACH KIT COMES WITH:
- 2x Bi-Xenon projectors, clear glass lens, ellipisoidal reflector bowls
- 2x 5100K *xenon HID bulbs for pure bright white output
- 2x DIGITAL brand SLIM HID ballasts (lifetime warranty!)
- 2x integrated angel eyes, super bright, in WHITE *
- 2x Fully integrated universal wiring harness with no-guess labels
- 2x mounting/alignment projector bases for following bulb types 9005,9006,9004,9007,H4,H1, and H7
- Instructions
- Sealant, no-splice wire taps, waterproof connection seals
* Other color angel eyes and bulbs are available.
Installation services are available
General install guide: http://www.retro-solutions.com/Produ...rojinstall.jpg
retrosolutions is offline
Old 08-17-2009, 10:16 AM
NothingBUTasian's Avatar
Default Re: DIY BiXenon Projector Retrofit Kits, LIFETIME WARRANTY
interesting
NothingBUTasian is offline
Old 08-17-2009, 04:11 PM
retrofits on a budget made easy, a fast way to better lighting.
Old 08-18-2009, 08:46 PM
vesnarrgh's Avatar
anything in a non angel-eye style?
vesnarrgh is offline
Old 08-19-2009, 02:45 PM
They all come with angel eyes, but they do not have to be hooked up, you can simply opt to not connect them.
Old 08-19-2009, 08:43 PM
RI's_DB1's Avatar
would you be able to do the 9004 kit but in 3000k bulb color?
RI's_DB1 is offline
Old 08-19-2009, 08:48 PM
9004 are not a problem, but 3000k we can not do for the bulbs these use.
5000k, 6000k, 8000k, 100000k are available
Old 09-03-2009, 08:37 PM
ATTENTION:
Please contact via email this coming week (5th-12th) as we will be on business in Europe and will not be available via other means.
Please please please do not send PMs.
Thanks guys!
EMAIL
Old 09-13-2009, 07:46 PM
all pms replied!
Currently a 0% failure rating on our projector retrofit kits!
Old 09-14-2009, 03:57 AM
Anon51's Avatar
what bulb size does this use? wondering if my current HID system would fit into the H4 Retrofit kit.
Anon51 is offline
Old 09-17-2009, 09:50 PM
These come with the bulbs, ballasts, everything needed. In addition your current kit bulbs would not fit/work with these projectors.
These come in the following applications:
H4
H7
9003
9004
9005
9006
9007
Old 09-18-2009, 06:30 AM
GUys we are getting a lot of awesome feedback on these, if you have photos of your installs please forward them to us so we can share with others.
Old 09-18-2009, 08:22 AM
GSaura's Avatar
What are the dimensions of the projectors used in this kit?
GSaura is offline
Old 09-22-2009, 09:07 PM
VERY GOOD QUESTION!
Projectors measure 130mm from apex of lens to back of the bulbs, only 90mm of this sits forward in the lamps when mounted, the rest sites through to the back of the reflector. The widest part measures 80mm diameter.
They are made purposely smaller to fit into some tighter housings where room may be limited.
Old 09-28-2009, 09:27 AM
all PM's replied.
Old 09-28-2009, 09:02 PM
New User
crazyjdm's Avatar
Is the projector the G1 or the G3?
crazyjdm is offline
Old 10-01-2009, 04:20 AM
G1 and G3 is some BS made up by someone pushing a product from a different manufacturer. There are no "generational" differences available for this exact product, there are different quality grades available though.
Old 10-08-2009, 06:28 AM
all PM's replied
Old 10-08-2009, 08:36 AM
UndisputedH22a's Avatar
so if i wanted brighter or different color bulbs how could i do that for these in H4?
UndisputedH22a is offline
Old 10-09-2009, 07:09 AM
The H4 models, and ONLY the H4 models, can use standard 35w D2S bulbs other than the ones provided. The bulbs we provide with them are wired a little differnetly though, this makes install much easier. We can do special orders for different color bulbs and different color halos too, just let us know.
These are only tested and supplied with 35w HID, we do not recommend using 55w with them as we have not tested for long term durability with 55w HID.
Old 10-09-2009, 08:12 AM
So if i wanted the 8500k Bright Blue with them i could get them for my H4 with your retrofit projectors
Old 10-12-2009, 05:01 AM
You will lose output with anything over 4300k, and we supply 5100k in most cases because they are still very bright an white with no yellow hint to them.
We can supply a special order 8000k with white, blue, or red halos (your choice) for teh same price. If this is what you would like to do, just PM us with your information.
Old 10-12-2009, 08:13 AM
ok i will be doin this in the future
Old 10-12-2009, 10:44 AM
Just contact us with you bulb color and angel eye color when you are ready!
Old 10-23-2009, 08:54 AM
all PM's replied!
