Digital Torque Wrench - Holiday Special
We ran this special last year during the holiday season and it got a great response. So we are doing it again!
The special is our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: HT
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until January 15th, and is only for the lower 48 states.
blmw
01-21-2013 07:27 AM
