Image Preview (if available) | Item # | Part | Price |
| 61759 | GRILLE chrome with emblem | $139 |
| 61760 | FRONT REINFORCEMENT 71130-SZA-A00 | $140 |
| 61761 | LH HEAD LIGHT oem 33150-SZA-A01 | $199 |
| 61762 | FR/L DOOR,CMPLET -MIRR -TRIM | $1000 |
| 61763 | 4DR RR/L DOOR,CMPLET -TRIM | $955 |
| 61764 | MASTER WINDOW SWITCH 35750-SZA-A01 | $75 |
| 61765 | 4DR RR/R OUTSIDE HANDLE | $15 |
| 61766 | FR/L DR PANEL CMPLET -SWITCH | $145 |
| 61767 | RR/R DR PANEL CMPLET check | $125 |
| 61768 | RR/L DR PANEL CMPLET 83751-SZA-A02ZC | $125 |
| 61769 | RR/R WINDOW REGULATOR 72710-SZA-A01 | $90 |
| 61770 | LH MIRROR black | $135 |
| 61772 | LH QUARTER PANEL | $875 |
| 61774 | LH TAIL LAMP,ON BODY, 33550-SZA-A01 | $99 |
| 61775 | DECK LID,complete,45 min repair need | $1300 |
| 61777 | REAR BUMPER CMPLET white with hitch | $465 |
| 61778 | FUEL PUMP | $99 |
| 61779 | ENGINE,MILES=31k,WARRANTY=6mo | $3200 |
| 61780 | FUEL TANK 17044-SZA-A01 | $145 |
| 61781 | FR/R SEAT gray cloth, blown bag | $199 |
| 61783 | F/L BELT Gray, retracts but needs ch | $0 |
| 61784 | F/R BELT,GRAY,NEEDS CHECK,RETRACTS | $0 |
| 61785 | 2ND ROW RH SEAT, smaller side | $175 |
| 61786 | 2ND ROW LH SEAT, bigger side | $225 |
| 61787 | 3RD ROW LH SEAT bigger side | $200 |
| 61788 | 3RD ROW RH SEAT smaller side | $165 |
| 61789 | DRIVER SEAT AIRBAG 78055-SZA-A00 | $199 |
| 61790 | LH ROOF CURTAIN AIRBAG 78875-SZA-A80 | $375 |
| 61791 | SPEEDOMETER CLUSTER,MILEAGE=31k | $299 |
| 61792 | STEERING WHEEL, perforated, nice | $99 |
| 61793 | HEAD LIGHT SWITCH | $0 |
| 61794 | WIPER SWITCH | $0 |
| 61795 | INSIDE REAR VIEW MIRROR | $0 |
| 61796 | Screen, non navi 39710-SZA-305ZA | $199 |
| 61797 | RH SUN VISOR, gray cloth | $39 |
| 61798 | LH SUN VISOR, gray cloth | $39 |
| 61799 | AT IGNITION SWITCH + KEY (check4ecu) | $250 |
| 61801 | 4DR RR/R VENT GLASS tinted | $90 |
| 61802 | RH QUARTER WINDOW GLASS tint | $145 |
| 61803 | LH QUARTER WINDOW GLASS tint | $145 |
| 61805 | AT TRANS,MILES=31k,WARRANTY=6mo | $1200 |
| 61806 | HARMONIC BALANCER | $35 |
| 61807 | AT JACK SHAFT 44500-S3V-A10 | $75 |
| 61808 | LH AXLE 44306-SZA-A01 | $125 |
| 61809 | FR/L LOWER ARM 51360-SZA-A04 | $160 |
| 61810 | 52390-STX-A01, RR/R UPPER ARM | $35 |
| 61811 | RR/L UPPER ARM | $35 |
| 61812 | RR/R LOWER ARM | $75 |
| 61814 | FR/L STRUT N SPRING 51602-SZA-A08 | $170 |
| 61817 | FR/L SPINDLE KNUCKLE | $150 |
| 61818 | FR/L BRAKE CALIPER 45019-SZA-A01 | $50 |
| 61819 | RR/R BRAKE CALIPER 43018-SZA-A01 | $50 |
| 61820 | RR/L BRAKE CALIPER 43019-SZA-A01 | $50 |
| 61821 | RR/R SPINDLE KNUCKLE | $140 |
| 61823 | ABS/VSA PUMP/MODULATOR 57110-SZB-A03 | $375 |
| 61824 | POWER STEERING PUMP 56110-RN0-A03 | $95 |
| 61825 | SOLD WITH #633(SEE IGNITION) | $0 |
| 61827 | ALTERNATOR 31100-RGW-A01 | $99 |
| 61828 | STARTER 31200-R70-A51 | $75 |
| 61830 | RADIATOR FAN ASSEMBLY | $125 |
| 61831 | AC FAN ASSEMBLY | $125 |
| 61832 | V6 RADIATOR 19010-RN0-A52 | $150 |
| 61833 | AC CONDENSER bent some | $0 |
| 61834 | AC COMPRESSOR 38810-RN0-A01 | $350 |
| 61835 | AIR CLEANER SETUP | $30 |
| 61836 | RADIATOR OVERFLOW TANK | $8 |
| 61838 | RR/L RIM,5 spoke 17" | $89 |
| 61839 | RR/R RIM,5 spoke 17" | $89 |
| 61900 | FR/R INT DR HANDLE, GREY, NICE | $10 |
| 61906 | FR/R LOCK ACTUATOR | $30 |
| 61910 | 32752-SZA-A20, F/R WIRE DOOR HARNESS | $20 |
| 61918 | FR/R WINDOW SWITCH, GRAY, VERY SCRAT | $0 |
| 62510 | FR/L FENDER LINER 74151-SZA-A00 | $35 |
| 62513 | ENGINE FUSE BOX, MISSING LID | $70 |
| 62517 | POS BATTERY CABLE 32410-SZA-A00 | $40 |
| 62558 | LH WIPER ARM 76600-SZA-A02 | $30 |
| 62559 | RH WIPER ARM 76610-SZA-A01 | $30 |
| 62568 | EGR PIPE | $42 |
| 62570 | FUEL PUMP | $85 |
| 62575 | BATTERY TRAY 60630-STX-A01ZZ | $25 |
| 62584 | PS BOTTLE | $50 |
| 62588 | WNDSHLD COWL | $50 |
| 62589 | DISCHARGE HOSE 80315-SZA-A01 | $15 |
| 62590 | SUCTION HOSE 80311-STX-A01 | $13 |
| 62595 | RR ENGINE MOUNT BRACKET | $32 |
| 62596 | FR ENGINE MOUNT BRACKET 50630-SZA-A0 | $16 |
| 62597 | fr/r bracket 51390-sza-a03 | $60 |
| 62599 | TRANNY MOUNT 50850-sza-a02 | $25 |
| 62600 | ENGINE SIDE MOUNT 50820-shj-a03 | $25 |
| 62607 | 18290-RGW-A01 REAR CONVERTER | $0 |
| 62608 | 36541-R70-A01, RR LAF SENSOR, | $70 |
| 62609 | 36542-R70-A01, RR O2 SENSOR, | $50 |
| 62610 | 18160-RN0-A01, FR CONVERTER | $0 |
| 62611 | 36531-R70-A02, FR LAF SENSOR, | $70 |
| 62612 | 36532-R70-A01, FR O2 SENSOR, | $50 |
| 62615 | 53713-SZA-A02, PS PRESS HOSE | $50 |
| 62616 | 53765-SZN-A02, PS OIL COOLER, | $35 |
| 62617 | 25510-RN0-003, ATF COOLER, | $70 |
| 62634 | RR ENGINE MOUNT 50810-SZA-A01 | $175 |
| 62635 | FR ENGINE MOUNT 50830-SZA-A01 | $175 |
| 62646 | AUTO PS RACK & PINION, | $250 |
| 62705 | INTAKE MANIFOLD 17160-RN0-A00 | $75 |
| 62706 | FUEL INJECTORS | $0 |
| 62707 | IGNITION COIL 30520-RN0-A01 | $0 |
| 62708 | EGR VALVE 18011-R70-A00 | $65 |
| 62725 | ENGINE COVER | $15 |
| 62728 | LH SIDE SKIRT 71850-SZA-A01ZA | $30 |
| 62735 | 39100-SZA-A01, TUNER ASSY AUTO RADIO | $285 |
| 62736 | CENTER CONSOLE COMPLETE, GRAY, NICE | $100 |
| 62755 | 17011-SZA-A01, CHARCOAL CANISTER, | $90 |
| 62758 | 57475-SZA-A02, RR/L ABS SENSOR, | $15 |
| 62760 | RR HEATER UNIT CORE 80225-SZA-A01 | $150 |
| 62761 | RR BLOWER MOTOR FAN | $65 |
| 62762 | CENTER WHEEL COVERS SET OF 4 | $0 |
| 62772 | FR STAB BAR, 51300-STX-A02 | $20 |
| 62773 | RR STAB BAR, 52300-SZB-A01 | $30 |
| 62774 | RR/R TRAILING ARM, | $30 |
| 62776 | RR/L LOWER ARM, | $75 |
| 62777 | RR SUB FRAME | $550 |
| 62780 | RR/R STABILIZER LINK | $0 |
| 62781 | RR/L STABILIZER LINK | $0 |
| 62782 | FR/L STABILIZER LINK | $0 |
| 62788 | 52345-SZA-A02, RR LOWER ARM, | $35 |
| 62824 | EXHAUSTT PIPE A 18210-SZA-A01 | $150 |
| 62895 | R/RR ARM A, 52345-SZA-A02 | $10 |
| 63561 | RR/R DOOR LOCK ACTUATOR, | $25 |
| 63564 | RR/R 2ND ROW, BLK SEATBELT, | $0 |
| 63565 | RR/R 3RD ROW, BLK SEATBELT, | $0 |
| 63569 | SUBWOOFER UNIT 39120-SZA-A81 | $75 |
| 63570 | BLK COMPLETE SPARE TIRE TOOL SET, | $45 |
| 63572 | ROOF RACK W/ CROSS BARS, | $250 |
| 63577 | RR CLIMATE CONTROL | $75 |
| 63750 | RR/R FENDER LINER | $25 |
