eg racecar shell + bare blocks + cyl heads + roller rockers
bare GSR head (no cams/no rockers/no rocker shafts/no valvesprings/no valvecover) the head does have cam caps + oil rails + bolts 300.00 +shipping
GSR head, is mostly complete minus cams 350.00 + shipping
bare GSR block with main caps sold
skunk2 gsr intake manifold SOLD
Ferrea roller rockers for b series (red ones)sold
"RHS" GSR cyl head, full ferrea valve train, custom valve springs. ported + polished + flowed, all work done by Eds racing heads + headgames motorworks. head is brand new still 2500.00 + shipping
__________________________________________________ _______
1992 honda civic si racecar chassis
***asking 5000.00***
(this does not include suspension/wheels/drivetrain)
* carbon fiber 1 piece front end (is currently in primer)
* 10pt chromoly cage with parachute mount/wheelie bar hookups
* Custom aluminum dash, door panels and interior panels, all painted gunmetal grey
* chromoly wheelie bar with wheeleze wheels
* stroud window net
* omp race seat
* FAL lexan windows (race kit) * Lexan sunroof *
* MB Products fiberglass doors with chromoly frames and lexan window with stainless allenhead bolts/nylock nuts
* Tube front end with midplate & chromoly timing belt side mount
* clearanced for 28" tires.
* Acura sundance gold pearl paintjob
* entire chassis was sand/bead/media blasted before paint
* spare tire well is cut out, with flat aluminum panel covering
__________________________________________________ _______________
__________________
Acura Integra race chassis 5750.00
this is pretty much a shell at this point. i bought the car, added a few things and never got to run it.
* 10 pt chromoly cage
*Jojo wide front end (closed mouth) mounted with tubular frame & dzues buttons
* custom aluminum under body tray/catch pan, with quick release mounts
* carbon hood and carbon trunk --color matched
* gas tank has full race sump installed
MOTEC M400 engine harness
built by me, with tefzel wire/raychem dr-25, deutsch connectors etc. 1200.00 OBO
*Harness is setup for 12 injectors, t1 cam trigger, emap, strain gage + all the other "normal sensors"
this is the harness before i added in the extra 4 injectors (it now has 12injectors )
__________________________________________________ ______________________________
JMF intake manifold for p72 head with wilson 105mm throttle body 750.00 shipped
* throttle body has vibrant 4inch v band flange welded on
*setup for 12 injectors
* i used this manifold with Golden Eagle MFG fuel rails, so any fuel rails for b series will . no need for custom rails
JM-Fabrications / Spearco water to air intercooler
* 4-inch v band inlet and outlet
* -12AN water outlet fittings
* -12AN drain
550.00 Shipped
lines/fittings for water to air intercooler
* 12an fittings on tank & intercooler
* 3/4 shut off valve on tank for drain
* hose is 3/4 inch
85.00 shipped
Hydraflow clamps 225.00 each
* fits 4inch tube
* i have 4 clamps
* OMC coils (coil on plug) with bracket
- fits b series vtec heads
225.00 + shipping
* eibach front and rear sway bar kit with endlinks etc, i belive its everything for installation. 250.00
Weld wheels
* weld spindle mount skinnies
Weld magnum spindle mount wheels (strange spindle)
1200.00 w/ the brand new tires on them
* stroud window net
* omp race seat
__________________
* -12AN drain
550.00 Shipped
* hose is 3/4 inch
85.00 shipped
* fits 4inch tube
* i have 4 clamps
225.00 + shipping
Weld wheels
