Mid-Atlantic (Sales) VA, DC, and MD
[VA] FS: 1991 Civic Si Teal Manual 90% Original $3500 OBO
Old 09-01-2014, 05:23 AM
Danronian's Avatar
Default [VA] FS: 1991 Civic Si Teal Manual 90% Original $3000 OBO
$3000 or best offer
1991 Civic Si
5 speed manual
Clean title (I'm the third owner. VA car, adult owned. Owned by two female teachers before I purchased it.)
Kenwood CD player with usb input and new speakers. Added rear optional oem speakers for a total of 4.
Original seats are NOT ripped
Lightweight OEM Honda wheels (from a Civic Hx but I do have the original wheels and hubcaps)
Koni Sport (yellow) Struts and Eibach Sportline springs (quality parts)
240k Miles (I still drive it so the miles may go up.)
Original motor (d6a6) and transmission (drives and shifts smoothly, this is the short ratio version)
A/C needs to be recharged but the system is intact/sealed minus the belt
Did not come with powersteering from the factory
Recently replaced parts:
Rear trailing arm bushings, rear sway bar bushings (black poly), rear upper control arms, rear lower control arms, passenger and driver's side half shaft axles, new brake fluid, rear wheel cylinders, spark plugs, distributor rotor and cap, ALL coolant hoses (OEM Honda), radiator, alternator belt, timing belt (30k miles ago), shifter bushings, front engine mount, fuel filter, stereo and speakers, struts/springs, front turn signal lenses (OEM Honda), manual transmission fluid, axle seal, rear exhaust section (OEM dual tip)
I will provide you with a service manual and all of the receipts and documentation from the work I performed on it.
Worn items:
Driver's side clear coat is peeling, small dent on the passenger side in the front of the rear wheel, small area of surface rust (4 inches approx) on the driver's side door at the bottom, small spot of 1/4 panel wheel-well rust on the driver's side, small rust holes on the inside front of each rear wheelwell (not visible or noticeable unless you are looking for them), driver's side seat is faded on the bolster, carpet is faded from being old and original, A/C needs to be charged, small hole in the one tail-light, leaks sometimes when it rains (sometimes in the front, back or both)
Overall this is a smooth running and shifting classic Honda. The interior is mint considering the age. I would like to keep it but I don't drive it enough and don't have enough driveway space to do so. If you want it, I will include the factory suspension. For the right price, I will also include a factory set of steel wheels with the OEM Si hubcaps. I do have some other OEM Honda parts I have ordered for the car and didn't yet install (like the outside window seals).
If you are seriously interested, bring cash and make me an offer. I will not entertain offers unless you come and see the car in-person. CASH ONLY!
Once you respond to this I will get back to you as soon as I can.
Danronian is offline
Old 09-01-2014, 05:25 AM
Danronian's Avatar
Default Re: [VA] FS: 1991 Civic Si Teal Manual 90% Original $3500 OBO
Located in 22485, King George, VA. 20 minutes east from I-95, 10 minutes west of 301.
Car does not smoke. Engine runs smoothly and quietly. Leaks little if any oil (not a leaker). Recently replaced the distributor o-ring as it did leak before I bought it. Does not burn or leak ANY coolant.
I will be 100% honest with you so if you have questions, just ask.
Old 09-02-2014, 02:14 AM
Danronian's Avatar
Any questions? Ask.
Old 09-02-2014, 04:11 PM
Danronian's Avatar
Still have it
Old 09-04-2014, 05:25 PM
Danronian's Avatar
Originally Posted by Danronian
Still have it
Old 09-13-2014, 02:59 AM
Danronian's Avatar
Price change to $3000 obo
Thanks!
Old 09-14-2014, 04:33 AM
Danronian's Avatar
Bump. Some offers and replies have been sent.
Old 09-17-2014, 02:09 AM
Danronian's Avatar
It went on a test drive last night but no cash in my hand yet.
Danronian
09-17-2014 02:08 AM
pastagarrett
07-19-2013 01:08 PM
patinum
12-25-2011 09:40 AM
BotCon25
09-01-2005 09:11 AM
MilwCivicSi
11-02-2004 07:12 AM
Quick Reply: [VA] FS: 1991 Civic Si Teal Manual 90% Original $3500 OBO
