Lighting HID/Xenon kits, Retrofits and Associated Topics
Where to put HID Ballast? 99' LX.
Old Jan 9, 2012 | 03:12 AM
Danny Sihapanya's Avatar
Default Where to put HID Ballast? 99' LX.
Where do you guys put the HID Ballast at?
Old Jan 9, 2012 | 03:13 AM
DA('s Avatar
DA(
Default Re: Where to put HID Ballast? 99' LX.
anywhere lolz
Old Jan 9, 2012 | 04:31 AM
Dontoh's Avatar
was going to put them in my fender to hide them, but wasn't 100% sure if they would be safe from water and other weather, so i used a bracket they came with and mounted them to the inside of my frame rails
Old Jan 9, 2012 | 04:32 AM
Dontoh's Avatar
but really, it doesn't matter as long as you can keep em safe
Old Jan 9, 2012 | 04:37 AM
Wrona's Avatar
No where get a retrofit and don't blind the f*ck out of people just because u want HID's its illegal and unsafe to have HID's in stock housings
Old Jan 9, 2012 | 06:30 AM
cvcrcr99's Avatar
If your ballasts are slim enough, you can slide them under the headlights for the to be hidden. Haven't had a problem with mine mounted there for the past 1.5 years.
Old Jan 9, 2012 | 06:42 AM
Well I can't see **** with my halogens. And my headlights are clean.
I guess I can try to put them under the headlights.
Well does it depend on the alignment if my lights are too bright?
Old Jan 9, 2012 | 08:25 AM
Wrona's Avatar
hid's wont help anything u'll think its brighter because theres going to be light dispersed all over the road which is bad and will get u a ticket get some OSRAM Nightbreakers or some phillips Xtreme or Sylvannia 4300k Bulbs its like 49 a bulb but u wont blind the sh*t out of people
and you need to adjust your headlights if you can't see anything
i couldn't see anything with hallogens than i adjusted them and i was able to see everything with Phillips Xtreme bulbs but than i got these ebay headlights for free and i had some M3 projectors so i put them into the ebay headlights and i have a proper HID Retrofit not some 10 dollar ebay bs that will melt your harness
Old Jan 9, 2012 | 08:40 AM
Bix VT's Avatar
yes please, some of us like to be able to still be able to see after you've gone past instead of being blinded.
Old Jan 9, 2012 | 10:20 AM
NOFX's Avatar
H-T White Ops
Swap to a '96-'98 Civic front end. I've had my '98 Civic for 9 years and never had an issue with light output.
Old Jan 9, 2012 | 11:28 AM
motegicivic's Avatar
Do you have factory oem light housings or aftermarket? Aftermarket ones the light disbursement is not the best.
Old Jan 9, 2012 | 11:30 AM
Wrona's Avatar
96-98 is great cheap to find because its easy to since ppl all want the 99-00 front end
Old Jan 9, 2012 | 12:41 PM
Factory.
And I wanna paint the chrome part black. Get that Type R Look. :D
But then I have to melt the seal stuff off in the oven and ughh
Lazy.
And HID's melt your harness?
Old Jan 9, 2012 | 12:42 PM
NOFX's Avatar
H-T White Ops
Black housing headlights do not look like Civic Type R headlights.
Old Jan 9, 2012 | 02:04 PM
Wrona's Avatar
Factory.
Lazy.
You've obviously have never seen a CTR up close or had the chance to own nice parts... the painted housings on stock headlights look like ebay headlights
and if you get a sh*tty kit yes there is a high possibility that it will destroy your harness happened to this kid at the car meet i was at a month ago
i have a HID kit retrofit from an M3 meaning projectors and The kit and i made myself a harness so i can make it plug and play without any splices
and the best part is i don't blind anyone on the road!!!
Old Jan 9, 2012 | 02:12 PM
EKphreak's Avatar
This.
Old Jan 9, 2012 | 03:30 PM
Tkrizz's Avatar
[QUOTE=Wrona;46650942]You've obviously have never seen a CTR up close or had the chance to own nice parts... the painted housings on stock headlights look like ebay headlights
You still need a ballast if im not mistaken though right?
Old Jan 9, 2012 | 04:19 PM
98civdx's Avatar
Master Detailer
Behind my front bumper, attached to the headlight bracket on the brace.
All the wires were tucked away, and hidden.
Old Jan 9, 2012 | 04:28 PM
Wrona's Avatar
nah i went to the junkyard and found a Audi and a BMW and bought the ballasts and got the bulbs for free so i have spares now i got it all for 5 bucks cause the chick didnt know wtf i had and everyone as on break
i just tucked mine into the fender
Old Jan 9, 2012 | 04:39 PM
Tkrizz's Avatar
lol nice ive been thinking about picking up some Mini H1's from a web site i found just don't know what ballast to use. Sorry to thread jack. I would think you could mount it anywhere that there is enough space just make sure to check the other side of whatever your mounting it to.
Old Jan 10, 2012 | 01:18 PM
Well I checked my engine bay and I have NO room for the ballast.
Ugh....
Now I have no idea where I should put them.
Old Jan 10, 2012 | 01:25 PM
otek // ek.dipn's Avatar
QQ
like
this
Old Jan 10, 2012 | 01:42 PM
NOFX's Avatar
H-T White Ops
Ugh....
Here's pics of a '96-'98 (all I could find, but should be similar enough) with the front bumper and fender removed. So you can see about how much room you might have there.
https://honda-tech.com/forums/showpo...62&postcount=3
(Btw, the information is wrong where he says you need to remove the fender to remove the headlight!)
Old Jan 10, 2012 | 02:05 PM
98civdx's Avatar
Master Detailer
Ugh....
Your kiding right?
I had WAY more then enough room to mount them in the bay.
I only went under the bumper becuase I don't want to see the ballasts.
Old Jan 10, 2012 | 02:41 PM
NOOdS's Avatar
you can put you ballasts anywhere. take off your bumper and hide it somewhere.
retrofit projectors look ugly. just a waste of money. i never got pulled over for my hids. never had a problem.
