Lighting HID/Xenon kits, Retrofits and Associated Topics
Signal switch problem. please help me
Old 10-30-2009, 10:30 PM
Etorres325's Avatar
Default Signal switch problem. please help me
Thanks ahead for the Help.
So, i just bough myself an EK hatch, Everything works fine, I just have a minor electrical problem with the headlight/turn signal switch.
Problem. The lights work and everything, when i turn the switch to the first click the cluster lights up and the signal lights light up. When i turn it all the way, the headlights come on(as normal) but the cluster turns off.
When i turn it right between the 1st and 2nd click the headlight and cluster light up, but then occasionally turn off due to it not being the proper spot for the switch.
Im thinking the contacts inside the switch just need to be cleaned. I was just wondering how i would go about doing that?
Can i be pointed in the direction of a thread if there is one already?
Thanks for reading/Help.
Old 10-30-2009, 11:39 PM
Etorres325's Avatar
Default Re: Signal switch problem. please help me
found solution to my own problem. dam i posted in 3 different forums. All views no help but here it is
http://www.b18c5eg.com/how2/lightswitch/
For a Eg but should be the same
redheadsSI
01-29-2010 06:08 AM
layinlow4dr
01-13-2010 08:08 AM
Etorres325
11-02-2009 06:29 PM
Etorres325
10-31-2009 06:06 AM
99delsol
09-14-2006 08:01 PM
Quick Reply: Signal switch problem. please help me
