projection headlight cant get hibeam wired correctly
So i recently got projection housings and some led headlights and they are a 2 pin plug. I have a 2000 civic which had a 3 pin and I've tried every wiring combination I can think of and nothing has worked out that I have both hi and low beams. My current configuration gives me low beams and I can pull back for hi beam but if I click them on, it shuts off my headlights but i figure that's because I don't have the hi beam wired to the led, just to the projector so that it will open when i pull back for flashing my hi beam. Any help would be appreciated.
Re: projection headlight cant get hibeam wired correctly
Am I correct to assume that on the headlight you have 2 separate lights, 2 plugs with 2 wires on each plug, for a total of 4 wires? And your OEM connection in the car is a single plug with 3 wires?
dmc12321
10-26-2015 02:03 PM
