Lighting HID/Xenon kits, Retrofits and Associated Topics
led problem
Old Apr 26, 2012 | 09:17 AM
theItalian's Avatar
Default led problem
hey im new around here...said hey in the new guy place...im sure this has already been addressed before but i couldnt find anything
i went to leds all the way around on the outside of my car...im having the normal rapid blinker stuff and i know i can get a resistor to fix that irritating problem
my problem though is when i went to replace the reverse and license plate lights...they dont come on at all
do they need a resistor as well?
am i going to have the same problem when i go inside to replace the gauge cluster lights?
on the blinkers can i put one resistor in any location on each side to fix the problem or does it need one for each side of the front and each side of the back?
sorry for all the questions from a newby
Dustin
theItalian's Avatar
Default Re: led problem
oh...i have a 94 civic dx...sorry
Old Apr 26, 2012 | 09:48 AM
ohbuckeyes's Avatar
-I did LED cluster lights, no issue with hyper flash.
- As to your reverse and and License plate lights, you should not need a resistor (I didnt on my buick and del sol) try flipping the led the other way, that should fix it.
- Resistors are the easiest way to fix the hyper flash as well. vleds.com has some that are easy to install and straight forward.
Old Apr 26, 2012 | 10:29 AM
theItalian's Avatar
well the reverse lights are an 1156 so theres no way to flip them around...the license plate lights ill try again...thought i had flipped them when i was out there but coulda been wrong...other than that or a resistor i have no clue what it could be because the normal lights work perfectly
thanks
Old Apr 27, 2012 | 06:11 AM
Hawkze_2.3's Avatar
Your LEDs may be defective, in backwards, or you blew a fuse. They should work fine in all the lighting circuits (other than fast blink in the signals).
Old Apr 27, 2012 | 07:13 AM
theItalian's Avatar
no...leds are good ( tried them in my pizza sign ) the lights/ circuts are fine with the old bulbs...thats what im using now...i was thinking this was a common problem...guess not lol...ill have to mess around with it alittle i guess and see what i can figure out
thanks for the help guys
Dustin
smitty2640
Dec 15, 2009 04:11 PM
Paul*DC4
Mar 31, 2008 05:01 PM
