Lighting HID/Xenon kits, Retrofits and Associated Topics
LED Door Light
Old Aug 7, 2011 | 05:57 PM
97CXHB's Avatar
Default LED Door Light
LED door marker light in progress.
Pics coming soon!!
Old Aug 10, 2011 | 08:18 AM
CDelgado220's Avatar
Default Re: LED Door Light
Same concept I'm assuming
Originally Posted by ex-r-wagon
Here is how I converted my door courtesy lights to LED.
Materials: Superflux red LED's (eBay 20 for $13.50 shipped), you need six for each light.
Prototype circuit board (I used some stuff from Radio Shack that I was given).
Your door light.
Start by removing the bulb from the light and cutting two strips of prototype board to fit into the light.
Then mount the LED's on the strips.
The LED's will come with resistors (you use these to limit the current to the LED's so they don't burn up!). The LED's mount Three to a board and use one resistor for each three LED's. The LED's are connected in series (anode to cathode or + to - if you like) and the resistor goes to the + side of the three LED's and the other end of the resistor connects to the positive contact of the door light.
The - side of the three LED's goes to the ground contact of the door light (use the end of the diode without the band).
Build the second strip and mount it as you see in the picture. The resistor ends going to the positive contact of the door light are soldered to the bulb contact as you see in the picture.
This DIY is aimed at those who have a basic understanding of LED's and how to wire them up for 12 volt operation. If you haven't played around with LED's jump right in and have fun, just be prepared to kill a few LED's as you learn.
Old Aug 10, 2011 | 09:40 AM
Blazin Si's Avatar
Loved
Community Favorite
It's always good to add a linear voltage regulator and filtering caps to your home made LED projects. You can't avoid voltage spikes with resistors alone.
Old Aug 11, 2011 | 04:44 AM
Oghma's Avatar
awesome work man :O
Why not do a led lighting on the outer door handle? Such as some luxury cars, some bmw's have it :b
( don't know if there's enough space to fit on a civic though. )
Old Aug 21, 2011 | 09:10 AM
rolow's Avatar
Can you tell me where you found that post? I want to install door lights in my eg so I need the entire light assemble and those look like they would work.
traxxasx
Aug 1, 2011 05:23 PM
zsudz922
Audio / Security / Video
Oct 1, 2009 02:21 PM
kcari
Honda Civic (2001 - 2005)
10
May 28, 2007 11:22 AM
phoenix_iii
10
Mar 15, 2006 06:20 PM
