Lighting HID/Xenon kits, Retrofits and Associated Topics
Interpretation needed.
Old Jan 5, 2008 | 01:38 PM
eskimo10's Avatar
Default Interpretation needed.
I was wondering if anybody could explain this diagram for me. I am doing a bi-xenon projector retrofit into my stock civic headlights and I can't get my bulbs to stay on when I flash my high beams on. This diagram explains how to do it but I can't quite understand it. Any help is greatly apprecaited!
http://img.photobucket.com/alb...P.jpg
Old Jan 5, 2008 | 09:44 PM
TehGhett0P1mp's Avatar
Default Re: Interpretation needed. (eskimo10)
Are you sure both relays work? Do you hear a clicking sound when they come on? If you wired it EXACTLY like that then it has to either be faulty wiring or something is reversed or something like that. Since your low beams work I would investigate the wiring for your high beams and see what you can find.
Old Jan 6, 2008 | 04:48 AM
eskimo10's Avatar
I haven't set it up like this yet b/c I don't quite understand how to do it. I don't get where the 85 and 86 go to.
Old Jan 6, 2008 | 02:36 PM
eskimo10's Avatar
Any one able to interpret the pic?
Old Jan 6, 2008 | 07:24 PM
JustG's Avatar
Default Re: (eskimo10)
It seems that there are 2 grounds and 1 12v power supply wires coming from the stock wiring on the car.. 1 ground for high beam and 1 for low beam and 1 common 12v.
For the highbeam relay:
85 goes to highbeam ground from car wiring for headlight
86 goes to 12v wire from car wiring for headlight
For the low beam relay:
85 goes to 12v wire from car wiring for headlight
86 goes to chassis ground
Hope it helps clarify. GL
Old Jan 7, 2008 | 05:46 AM
devani's Avatar
the wire harness is made for ground switched cars....
First tell us what year it is....then we can help...
Old Jan 7, 2008 | 05:54 AM
eskimo10's Avatar
I figured it out, thanks for the help. Its a 98... which is a positive switched car. Got the right one from the guys at HIDplanet.com
fergs96integra
Jun 28, 2009 09:44 AM
viet_tec
Dec 22, 2007 12:40 AM
tuterz
Lighting
Sep 12, 2007 04:54 PM
4G Addict
May 17, 2007 12:22 PM
Topdawgg
Apr 11, 2007 10:10 AM
