Headlight wiring problem, ground?
Old Jun 27, 2009 | 09:52 PM
fergs96integra's Avatar
Default Headlight wiring problem, ground?
First off the car is a 1996 ls integra.
So i got my car wiring all done, but when i turn on my parking lights everything is fine. When i turn on my headlights the left turn signal turns on but dim, and also my high beams, both sides, are on but dim as well kinda like city lights but i don't have it wired up for it. When i hit my high beams, the left side goes out, and the turn signal goes back to normal. Right side works perfectly other than the high beam being dim. Any help would be great and if anyone has any wiring diagrams so i can find the grounds that would be great thanks.
Old Jun 27, 2009 | 10:26 PM
on-site ej1's Avatar
Post Re: Headlight wiring problem, ground?
what year make and model is the car?? ill try and get a diagram for you of the acura website.
Old Jun 27, 2009 | 11:04 PM
ek-g6's Avatar
Default Re: Headlight wiring problem, ground?
sounds like ground, check to see if the ground pack have a good connection with the chassis.
Old Jun 28, 2009 | 09:39 AM
not sure if this link will work, heres a diagram for the headlights, i hope you know how to read it. http://tor.in.honda.com/Rjanisis/RJAAI003_205.htm
Old Jun 28, 2009 | 09:44 AM
so the dumb *** link didnt work ill try and figure out how to put it on here.
jdm_ek_noob
12
Apr 8, 2014 04:10 PM
Lozano1991
Apr 21, 2012 08:32 PM
gregRULES
Feb 27, 2011 01:01 PM
Kellindal
Oct 8, 2006 10:38 AM
CapriSunIsTasty
Audio / Security / Video
Apr 27, 2003 07:15 PM
