Lighting HID/Xenon kits, Retrofits and Associated Topics
Indiglo cluster
Old Jul 20, 2011 | 06:36 PM
jumpin4abeat's Avatar
Default Indiglo cluster
So I purchased a cheap cluster to basically test my speedo/odometer problem. It solved that problem but the cluster has 3 extra tiny harnesses coming out from it. I figured they are the lights for the guages because its dark when I turn my lights on. It did not come with anything to attach onto these connectors so I was wondering if I can just cut the connectors off, splice them all together so all three are basically 2 wires only and then tape into the factory dimmer switch and run the ground? If so does it matter which wire I use as the power and switch I use as the ground?
b18c1del
Aug 22, 2009 01:25 PM
dravesef
Jun 19, 2008 03:46 PM
ge_ej1
Jan 31, 2008 09:00 AM
ApexIS300
Jul 16, 2004 06:15 AM
Frog
Nov 8, 2002 11:51 AM
