Lighting HID/Xenon kits, Retrofits and Associated Topics
How bad is this glare
Old Jun 17, 2009 | 12:16 AM
CivicSD's Avatar
Default How bad is this glare
Just did a PNP kit 6000k.
How bad is this glare, in your professional opinions ?
Old Jun 17, 2009 | 12:32 AM
allentownrep's Avatar
Default Re: How bad is this glare
if your headlights dont have projectors thats whats going to happen. HIDS are meant to work in conjunction with Projectors.
Old Jun 17, 2009 | 12:39 AM
AmviciousRav's Avatar
you need a retrofit...or mayb aim the hids lower (if possible?)
which car is that btw?
Old Jun 17, 2009 | 12:46 AM
CivicSD's Avatar
Thanks for the replies, fellas.
My DD... a Nissan
Old Jun 17, 2009 | 10:57 AM
HGZ's Avatar
HGZ
if your headlight housings utilize H4 bulbs, you might be able to get some casper shields.
i have no experience with them but i've heard lots of people use them to help reduce the upwards glare that you get with reflector housings like yours.
if you got H4 headlights, might be good to look into 'em! a little expensive for $25 each though.
hopefully someone who has experience with the casper shields can chime in
Old Jun 17, 2009 | 11:10 AM
CivicSD's Avatar
^^ I already have the casper shields installed !!
Old Jun 17, 2009 | 11:36 AM
HGZ's Avatar
HGZ
well shoot..
the only other thing i can think of to minimize glare is to make sure your headlight's lenses are SUPER clean and clear. if they are fogged up or yellowed or just plain have dirt on them it will cause glare.
my headlight lenses are a tiny bit dull and causes a lot of light to appear above my cutoff line with my pnp kit. but i just take some meguiars Plastix headlight cleaner to make them clear again and it really helps get rid of glare and light appearing above the cutoff.
Old Jun 17, 2009 | 11:56 AM
Strate L O S S's Avatar
casper shields can be bought on ebay for a bit less.
OP, try painting the shields a flatfinish(silver or w/e color)
Old Jun 17, 2009 | 01:19 PM
denshu's Avatar
Plug and play Glare
retrofit TSX No Glare
Old Jun 17, 2009 | 01:54 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
ahhh my eyes! Damn that's even WITH the casper shields? Horrible glare on that man. You should not use those on public streets. Ever.
Old Jun 17, 2009 | 03:47 PM
CivicSD's Avatar
oh come on get off your high horse...
Old Jun 17, 2009 | 04:45 PM
Community Builder
no horses around here....
Old Jun 17, 2009 | 05:42 PM
CivicSD's Avatar
You've been reading a little too much of Daniel Stern Lighting.
Seems like a lot of the retrofit HID guys love to bash on PnP kits. Yeah, PnP is not perfect but it's also not as bad as you make it seem.
I don't want to come off as a hater We're both 02's here, gotta have respect....
Old Jun 17, 2009 | 06:52 PM
Community Builder
I am THE PnP Hater lulz check the sticky at the top of the forum to see why.
Old Jun 17, 2009 | 08:18 PM
e46civic's Avatar
I guess that makes me 2nd in line. Don't Infinitis have an HID option, with an awesome high beam projector that looks cool and functions well?
Old Jun 18, 2009 | 10:08 AM
CivicSD's Avatar
I realized i actually had the bulbs in crooked. Didn't know I have to twist them to lock in place, ill see if the cutoff has changed at all...
e46civic, Yes there are optional HID's.
The first option is JDM, but not easy to find cause i dont speak Japanese and nobody imports them it would be direct bolt in
then theres the newer generation USDM projectors, which can be custom fitted by just cutting the grill, but they sell for $500 EACH SIDE !!!! (junkyard pricing)
Old Jun 18, 2009 | 10:15 AM
Community Builder
I believe those oblong projectors are for high beams. Still has reflectors for low beams.
Old Jun 18, 2009 | 10:19 AM
CivicSD's Avatar
yeah but they are HID reflectors
Old Jun 18, 2009 | 07:21 PM
e46civic's Avatar
Sorry I didnt realize you had the 1st gen. Even though its a reflector, it will still not have the glare the stock halogens do, and $500 apiece is too much. Quite awhile ago I lost a bid on ebay for 3 complete headlights for $150( I just wanted the ballasts)! I didnt know there were JDM versions, I actually think its kind of gaudy.
Old Jun 19, 2009 | 03:20 PM
96DelSol's Avatar
Kinda bad, but not too bad for not having projectors.
Old Jun 19, 2009 | 03:38 PM
doubleshotz's Avatar
seen worse but thats all bad...
what bulbs you use?
Old Jun 21, 2009 | 11:25 PM
CivicSD's Avatar
UPDATE
i have been high beamed twice so far - both times i turned on the high beams as a reply, and lit up the other car like daylight!!! Its so funny to see the expressions on the peoples faces
both times was on narrow straight roads where the oncoming traffic is headed straight for you
but yeah you guys were right about PnP! i thought i was so smart!
86belated
Jul 27, 2012 05:38 AM
1991hb
Jul 31, 2010 03:54 PM
triple5soul8781
Lighting
Aug 10, 2008 10:54 AM
Neo_2006
Oct 12, 2006 11:52 PM
GokuSs4
Sep 23, 2004 04:24 PM
