Lighting HID/Xenon kits, Retrofits and Associated Topics
HID hELP..
Old Oct 16, 2007 | 07:48 AM
Spoonsinglecam's Avatar
Default HID hELP..
i NEED HELP FINDING SOMETHING TO HOLD MY HIDS IN PLACE. iM USING DUCT TAPE FOR NOW. but my car has alot of bounce to it and wen i notice the bulbs start to aim downards. anybody got some info on wat i can use?/
Old Oct 16, 2007 | 12:18 PM
dc2Li's Avatar
Default Re: HID hELP.. (Spoonsinglecam)
haha zip tie on on the radiator support
Old Oct 16, 2007 | 05:07 PM
Default Re: HID hELP.. (dc2Li)
i did dat already but u gotta understand i seen ppl use these plastic plates that u insert the bulbs and they stay with no problem..
Old Oct 16, 2007 | 06:36 PM
Padawan's Avatar
Darth ModerVader
Why don't they lock in to place like your original bulbs? Is this a kit you're using, or did you just try to jam OEM HID capsules into your stock lights?
Old Oct 17, 2007 | 03:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
hmm sounds like the latter.... holding bulb in with duct tape... so sad
Old Oct 17, 2007 | 04:48 AM
devani's Avatar
Default Re: (PatrickGSR94)
We do have some creative ideas already...
duck tape, zip tie, plastic plates...
OMG if you used OEM stuff you would not have this...
I say JB weld..or any kind of glue but this thread is so funny..
Old Oct 20, 2007 | 05:44 AM
imroadk1ll's Avatar
wat kind of car do u have dude. this only would happen if u have an rsx.
Old Oct 20, 2007 | 08:08 AM
Community Builder
Default Re: (imroadk1ll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imroadk1ll &raquo;</TD></TR><TR><TD CLASS="quote">wat kind of car do u have dude. this only would happen if u have an rsx.</TD></TR></TABLE>
What does an RSX have to do specifically with this thread?
Old Oct 20, 2007 | 05:01 PM
operatic's Avatar
What type of bulb is being used? And what kind of car is this for?
Old Oct 21, 2007 | 09:24 AM
Default Re: HID hELP.. (operatic)
97 honda civic.. stock headlights..im tryin to figure out with that rubber cover the stock lights comes with will it fit. do i have to do any mods or anything?? i have h4/9003 bulbs.. not a bad kit for 120 with waterproof ballasts and purple bulbs with pink highbeams..
Old Oct 21, 2007 | 02:12 PM
operatic's Avatar
Your HID bulbs should have a base like the picture below. Now there is a metal clip that holds the bulb onto in the headlight. The metal clip is part of the headlight that is secured in by a screw. If you don't have it, then your bulb won't stay in.
As for the rubber grommet, just run the wires of the bulb through the middle of the rubber grommet.
Old Oct 21, 2007 | 03:34 PM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoonsinglecam &raquo;</TD></TR><TR><TD CLASS="quote"> purple bulbs with pink highbeams..</TD></TR></TABLE>
ewww that sounds extremely crappy and ugly why the crap would you want PINK high beams???
Old Oct 22, 2007 | 04:15 AM
Default Re: HID hELP.. (PatrickGSR94)
pink highbeams looks like a deeper purple..and u gotta understand its for show only. u kno when ppl is showin off i dont turn em on often. i use the purples for street use.
Old Oct 22, 2007 | 04:16 AM
thx man..ur about the only helpful person on this thread...
Old Oct 22, 2007 | 06:21 AM
Community Builder
So do you have rebased bulbs or are you sticking OEM D2-based HID bulbs into your stock housings?
Old Oct 22, 2007 | 06:55 AM
dis is wat i did...i bought these black housings on ebay..they didnt come with that metal pin with the screw like the oem ones have. so i fit the tabs to the appropriate slot.. den i made sure the aim angle was all the way up and i got sum adhesive that turns into metal and then put heat proof ducttape that way the power steering and/ or any other heat will burn thru my wires..im using some aftermarket hid kits with dual bulbs.
CrazyModGSR
May 4, 2004 04:13 PM
CrazyModGSR
Apr 29, 2004 07:57 PM
TypeR 599
Apr 4, 2004 01:19 AM
APEX i GSR
Mar 8, 2004 09:56 PM
geminis2k
Nov 4, 2003 12:02 PM
