Lighting HID/Xenon kits, Retrofits and Associated Topics
Hid Bulb
Old May 29, 2008 | 03:55 PM
Accord1234's Avatar
Default Hid Bulb
Is it true that D2R hid bulb is the same as D2C?
Old May 29, 2008 | 04:07 PM
DrivenMC's Avatar
Banned
Default Re: Hid Bulb (Accord1234)
D2C fits Both D2R & D2S, although D2R has an optical Shield.
Old May 29, 2008 | 08:41 PM
Accord1234's Avatar
Default Re: Hid Bulb (DrivenMC)
What do you mean by an optical shield. Cause my friends car came standard with D2R and I ordered D2R 10K and I would up with D2C 10K. The cars a 2008, I don't wanna make any problems. Thanks Tommy
Old May 29, 2008 | 09:59 PM
bpr0422's Avatar
The D2C is an after market thing, it doesn't have the shield that prevents glare...
no OEM bulb goes to 10K, also why are you going to 10k?
doing so will only reduce the intensity of the light... and you are basically downgrading...
just go and buy real oem replacement bulbs, and save other drivers from glare...
Old May 30, 2008 | 04:09 AM
DrivenMC's Avatar
Banned
Default Re: Hid Bulb (bpr0422)
Consider My Products, Xenonworx Bulbs Come with a 2 year warranty. You get OEM Quality with a Warranty.
Old May 30, 2008 | 04:16 AM
DrivenMC's Avatar
Banned
You will notice that the D2R Bulb has the Optical Shield Vs. the D2S that doesn't.
D2R bulbs are used in Reflector HID housings
D2S bulbs are used in Projector HID housings
Old Jun 1, 2008 | 07:22 PM
Accord1234's Avatar
Ok thanks. Do you happen to sell the 55 watt Hid Kit?
Old Jun 1, 2008 | 07:27 PM
DrivenMC's Avatar
Banned
No, your vehical needs to be rewired to properly give the ballast the power it needs to run. Do to this fact we don't sell 55w ballast.
Old Jun 2, 2008 | 04:25 PM
Accord1234's Avatar
Why does it seems that when I watch videos of people installing hid kits there all come with a relay and get wired to the battery but mine has no relay and just gets wired into the factory harness.
Old Jun 3, 2008 | 09:03 AM
DrivenMC's Avatar
Banned
Most aftermarket HID systems Draw more Amperage than your vehicle's harness is capable of handling. So these kits need relays to make the ballast work efficiently.
Old Jun 7, 2008 | 07:28 AM
Accord1234's Avatar
Ok. Thanks
TurbothisLS
Sep 30, 2016 08:42 AM
JforJonathan
Mar 13, 2004 01:10 PM
geminis2k
Nov 4, 2003 12:02 PM
SilverDc2
Nov 26, 2002 10:06 PM
Todatyper
Dec 27, 2001 04:06 AM
