Lighting HID/Xenon kits, Retrofits and Associated Topics
hid ballast differences??
Old Jan 15, 2008 | 08:08 PM
cilvia's Avatar
Default hid ballast differences??
are there any differences between the ballasts for HIDs?? can i put different kelvin bulbs with any of them??
Old Jan 16, 2008 | 11:54 AM
prelude1897's Avatar
Default Re: hid ballast differences?? (cilvia)
yes there's a difference in ballast. You have your OEM ballast and your cheap aftermarket ballast. You have ballast that require D2S/D2R bulbs, D4S/D4R bulbs, and D1S/D1R bulbs. Then you have the cheap aftermarket ones that have whatever size bulbs you need for your car
Old Jan 16, 2008 | 01:29 PM
cilvia's Avatar
Default Re: hid ballast differences?? (prelude1897)
besides bulb sizes can i put different kelvin temperature bulbs in them??
Old Jan 16, 2008 | 02:15 PM
Padawan's Avatar
Darth ModerVader
If your ballasts use the AMP connectors typically found on aftermarket kits, then you can purchase new aftermarket capsules that generate a different Kelvin temperature (assuming they use the same AMP connectors). Most OEM capsules are only available in 4300K or 6000K and do not use AMP connectors.
Old Jan 21, 2008 | 07:40 PM
kawgomoo's Avatar
you can still get a D series connector to connect a d based bulb like d2s d4 etc to a regular aftermarket ballast.
color temp makes no difference. if the bulbs will plug into the ballast you are good to go.
XenonDepot
22
Jun 17, 2010 11:15 AM
v-tec23
Lighting
Apr 11, 2008 10:25 AM
kcari
Honda Civic (2001 - 2005)
Aug 19, 2007 09:52 AM
JforJonathan
Mar 13, 2004 01:10 PM
geminis2k
Nov 4, 2003 12:02 PM
