Lighting HID/Xenon kits, Retrofits and Associated Topics
HID
Old Nov 12, 2007 | 07:18 PM
PinoyDelSol's Avatar
* B A N N E D *
Default HID
hey guys, well i got a free HID kit from my friend and installed it on my 94 Del Sol.. Everything fits correctly, but my main concern is that in order to have my HIDS to light up i have to have the high beams on.. I wanted to have the HIDS on my low beams but it doesn't seem to work. Im not to sure on the brand kit i have but i know it is 10,000K Blue something. How would i be able to run my HIDS on low beams instead of running them on the high beams.. Its really irritating me to run them on high beams and that blue light symbol for the high beams is annoying when its on too.. help pretty please..
Old Nov 12, 2007 | 07:59 PM
bpr0422's Avatar
Default Re: HID (PinoyDelSol)
umm...
doesn't the delsol use h4 bulbs?
if it does.. then you need to just switch the power leads on the h4 adapter harness.
then you can go mmm glare and omg no highbeams!
Old Nov 12, 2007 | 08:04 PM
* B A N N E D *
Default Re: HID (bpr0422)
yes sir the del sol uses h4 bulbs.. but what where is the power lead that is on the h4 adapter harness?
Old Nov 12, 2007 | 08:11 PM
bpr0422's Avatar
There are 3 pins on the h4 plug..
there is 1 ground and two positives or one positive and two grounds.
see how it is hooked up, and just switch it..
edit: the common one is the left most pin, with the middle facing up...
to switch it, just de-pin the terminal on the HID ballast's harness.
Modified by bpr0422 at 9:42 PM 11/12/2007
Old Nov 12, 2007 | 08:22 PM
* B A N N E D *
alright thanks anyways.. seems kind of hard for me too do.. not a electrical person lol.. i know what you are talking about now though.. good info though and thanks!
Old Nov 12, 2007 | 08:44 PM
bpr0422's Avatar
i added a diagram.
Old Nov 12, 2007 | 09:05 PM
* B A N N E D *
nice.. So which one do i de-pin? My HID H4 plug or my cars Factory H4 Plug? And how do i de-pin that sir?
Old Nov 12, 2007 | 09:37 PM
bpr0422's Avatar
you depin the aftermarket one..
your aftermarket harness should only have 2 wires..
see which is ground and which is positive.. and move the pins.
to depin.. there might be clips or a tab you have to press with a very small screwdriver...
Old Nov 12, 2007 | 09:40 PM
* B A N N E D *
ohh so basically all i have to do is try to get the pins out and switch them around in order to work with my low beams? Seems alil hard and risky but i guess i can try it.. This wont blow my hid bulbs faster will it?
Old Nov 13, 2007 | 04:39 PM
bpr0422's Avatar
... how would it do that?
you are switching the pins on the after market conversion harness.. cause for some odd reason they are switched...
Old Nov 13, 2007 | 06:02 PM
* B A N N E D *
alright i will take a peak at it..
gosu08
Dec 8, 2012 06:56 PM
itsmejto
Jun 22, 2008 04:11 AM
PinoyDelSol
Lighting
Nov 16, 2007 04:44 AM
phantom_sol
19
Jul 15, 2003 08:58 PM
