headliht wireing
where would i begin to look for bad wireing? bought a H.I.D. kit and only my high beams work ( the kit comes with high and low beam) would i be able to get a headlight harness from autozone or something? or how can i figure what the problem is with my regular lights are not working?
Might want to double check to be sure you have everything hooked up correctly. Double check your grounds and double check how you have the positive side of the power wires hooked into your stock harness
JDMhatchback20
Nov 10, 2004 04:36 PM
