Lighting HID/Xenon kits, Retrofits and Associated Topics
electrical probem
Old Oct 31, 2007 | 06:07 PM
ahhsimon's Avatar
Default electrical probem
i got an electric problem in my car, the function works but like my instrumental lights dont work, my signal dont work
my emergency lights work but when it goes on only the left signal turns on and then when i signal right with the emergency light on the right signal goes on but when i dont press the emergency light both my signals dont work
my head light signals turn on but dont signal when signal
another symptom is when the emergency light is on, and u turn off the car and take out the keys and left hte emergency light on the car stays on .. its all weird ..
someone please tell me whats wrong
when i turn on the emergency light on and my headlights are off my instrumental light goes on
i checked all the fuse everything is working .. something is wrong wire loose or something i dont now where .. i tooked off the front end and try to find a problem but everything seems fine .. i did get a front end accident recently though, all wires are in tact
some body helpppp
Old Oct 31, 2007 | 07:18 PM
bpr0422's Avatar
Default Re: electrical probem (ahhsimon)
translation..
I have an electrical problem with my car. The lights work, but my dash/instrument lights don't work, and my turn signals don't work.
So you mean just your headlights work? what about your tail lights? Give us a list of all the lights that work and don't work. A list...not a paragraph...
* Left Low-beam - Y/N
* Left High-beam - Y/N
* Left Front Parking Light- Y/N
* Left Front Turn Signal - Y/N
* Left Side-marker - Y/N (If you have side-markers)
* Left Rear Stop Light - Y/N
* Left Rear Parking Light - Y/N
* Left Rear Turn Signal - Y/N
* Left Reverse Light - Y/N
* Rear Fog Light - Y/N (if you have a rear fog light)
* High Mount Stop Light - Y/N
* Right Reverse Light - Y/N
* Right Rear Turn signal - Y/N
* Right Rear Parking Light - Y/N
* Right Rear Stop Light- Y/N
* Right Low-beam - Y/N
* Right High-beam - Y/N
* Right Front Parking Light- Y/N
* Right Front Turn Signal - Y/N
* Right Side-marker - Y/N (If you have side-markers)
* Instrument/Dash Lights - Y/N
translation..
My turn signals only work when my hazard light switch is clicked ON.
translation..
my front turn signals light up, but don't blink when I signal
That is normal... those are your parking lights... they turn on with the first click of the light swtich.
translation..
Another symptom is when the hazard light switch is ON, and you turn off the car and take out the keys.... the hazard light stay on.
This is normal, you hazards are supposed to work even if the car is off, as long as your battery has power, you hazard lights will work.
translation..
when i turn on the hazard lights, and my lights are off - my dash/instrument lights turn on
This is another wire that has shorted out somewhere...
translation..
I have checked all the fuses, and they are not blown. Something is wrong. I think a wire is loose - or something - but i don't know where. I took of the front end of my __(car?)__ and tried to find a problem, but everything seems fine. I did get into a frontal accident recently though, but all wires are in tact
Okay, after going through your post.. slowly... I hope i read it right.
I think your problem is somewhere toward the front of the car. You said you got into an accident right?
Did you get it fixed at a body-shop? and how bad was the damage.
It sounds like either the parking light wire is shorting out with your turn signal wires.. OR the body-shop you took it to, screwed up your electrical.
If your body-shop screwed up your electrical.. then I suggest you bring it back... its really their problem.. because it is their responsibility to get your car up and running again... so you shouldn't have to pay extra for any other repairs.
Modified by bpr0422 at 8:29 PM 10/31/2007
Old Oct 31, 2007 | 07:35 PM
ahhsimon's Avatar
Default Re: electrical probem (bpr0422)
the damage was teh whole front end replacing the radiator support and radiator, ac condensor is still on btu needs to be replaced also
yeah i can bring it to the shop but i want to deal with it because i dont really have that much time to drop it off at the shop again, im always at work or schoool
Old Oct 31, 2007 | 07:52 PM
bpr0422's Avatar
If the damage was the whole front end, and you had to replace the radiator support...
thats a lot of damage..
Its like i said, either the parking light wire is shorting with the turn signal wire or the body-shop did a number on your electrical system.
Up front, lighting wise, there are only 8 wires: Left Turn Signal, Right Turn Signal, Left Low-beam, Left High-beam, Right Low, Right High, Parking Lights, and ground.
The head lights have 3 wires each, high, low, ground, and your corners have 3 wires each, parking, turn, and ground.
To check if they are shorting out.. you are going to need a multimeter... and check for continuity between the parking light wire, and turn signal wire - on each side.
If the resistance is 1, then u have no continuity, if it is a value less than one.. you have some continuity...
Also when you turn on your hazard lights, you said that your dash lights turn on - do they blink on/off?
Old Nov 1, 2007 | 06:24 AM
B16B_coupe's Avatar
HRD PKR
sometimes people leave the green plug undone on the switch and turn signals etc wont work, but i would check all your headlight wire from cuts etc, and also make sure the ground wires arent cut and are tight on both sides
Old Nov 1, 2007 | 10:04 PM
ahhsimon's Avatar
Default Re: electrical probem (B16B_coupe)
oh man after hella god damn headaches .. i cant believe i found out what it was !! after doing the turn signal/hazard relay inspection i thoguht it was a ground seriously !!! so i opened the damn hood, search for all the damn ground , sand the **** out of them but nothing worked. ...but damn after ******* around .. and remember the last thing that i did to the car .. and i was like hey .. wat if i switched the hazard buttom, luckily i still had my old one ... and then everything start working again .. i laughed my *** off on how ridiculous it is !! and who i got to thank for my progress??? no one but ron J of hondacivicforum!!! thanks man
Old Nov 1, 2007 | 11:07 PM
bpr0422's Avatar
haha.. actually i was thinking it also could be a bad hazard light switch... or that is where the short was...
but u were talking about front end damage...
Old Nov 2, 2007 | 09:13 PM
ahhsimon's Avatar
yeah o was thinking it was a short, a bad ground, an open wire, a broken fused. .i checked hella stuff.. i even sanded down some places thinking it was a bad ground or something .. but then i did some of the hazard tests that was given to me from someone else
i tooked the turn signal/hazard relay out and connect 1 and 3 together and the emergency light went on ... that mans i had a bad ground .. so i try to find every single ground and .. nothing hpapened .. then i was thinking .. or it can be a bad hazard swtich.. so i switched that and ... next thing i know everything worked ....then i lmao on how a stupid **** like a damn button expletive everything up
and yeah the front end damage could have been the source of my problem you know but i guess it was it wasnt
r
but other then that i found out a way to change the color of my climate control a lot easier than welding in bulbs with solder, what u do is u take the same kind of bulb and socket from the guage cluster and u use it in the climate control, and just change the bulbs to led
98dxkoupe
May 18, 2015 01:54 AM
Slabre
Sep 17, 2009 04:04 PM
ahhsimon
Nov 1, 2007 10:05 PM
tearinox
Oct 19, 2006 06:49 PM
integrx
Jan 27, 2004 03:12 AM
