Need help with my projector headlights
New User
Sup all
I have projectors headlight in my 92 civic but the light went out so i went to my local autoparts place and accidently bought 100 watt bulbs (h3). I think the stock bulbs are 55 watt. Anyways, couple weeks later, the passenger side headlight went out so i replaced the bulb but it still doesnt work. Is my headlight wiring fried from using higher wattage bulb? anyone know how to fix this problem? thanks
Re: Need help with my projector headlights (civicnightracer)
I'm running a 55w and seventy something watt bulb in my projectors, haven't had a problem. I doubt the wiring is fried unless you visably can see something is wrong Usually the fuse will go out first. Were your sure the bulb wasn't fried already? Try buying a stock style h3 bulb for like 12 bucks at Walmart or somewhere. See if it works. Make sure they are cleaned up good before you put them in also, I wipe it down with a lint free cloth and alcohol.
Good luck
Good luck
New User
Re: Need help with my projector headlights (PapaVTEC)
yea, i tried replacing it with the stock 55 watt bulb but it doesnt work so i guess its either the fuse or the wiring. does anyone know which fuse i have to replace? i lost my fuse box cover so i dont know which fuse i have to replace. thanks
Re: Need help with my projector headlights (Boost Pressure)
this might help...
92-95 Civic interior fuse panel. I lost mine too.
[Modified by Barabus, 9:59 AM 1/18/2002]
accord ex
03-13-2003 05:55 PM
Night Kid
01-30-2002 10:42 PM
