Lighting HID/Xenon kits, Retrofits and Associated Topics
Driver side tail light not working
Old Jul 6, 2022 | 08:15 PM
patatazintegra's Avatar
Icon4 Driver side tail light not working
Hey, so if anyone could help me diagnose the issue it would be very helpful.
I have a 99 Integra GS, recently I replaced 1 of the tail lights (driver side) because I got into a minor fender bender. The old tail light worked properly and never had an issue. But since changing it to the new tail light ( 2 days ago) I realized that the light does not work? I checked the fuse but that cannot be the issue since the passenger side one is working I tried switching the bulbs but that didn't do anything either. I don't know what else the issue could be. if anyone knows please respond thank you.
I attached a video of the problem as well.
File Type: mov
Old Jul 9, 2022 | 02:25 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Driver side tail light not working
Wiring probably was damaged.
Measure if there is voltage on the Red/Blk wire (red wire with black stripe running through it). If there is ~ 12volts there, then it probably is a ground wire issue. If there is no power on the Red/Blk wire, then there is an open (break) in that wire.
Old Jul 11, 2022 | 08:33 PM
Yes, it was the wiring. took it to my mechanic & he checked the voltage. ended up DC the wire to the other tail light.
Thank you for the response i appreciate it.
03civiclx
Honda Civic (2001 - 2005)
Jul 10, 2009 11:05 PM
jlow125
Aug 31, 2008 03:48 PM
FastKTJ
Dec 15, 2007 07:39 AM
