Lighting HID/Xenon kits, Retrofits and Associated Topics
disassembly of rear lights
Old Dec 3, 2007 | 12:16 PM
mikeycivic's Avatar
Default disassembly of rear lights
How would one go about taking the rear tail light lenses apart? What would be good temp for the oven
Old Dec 3, 2007 | 12:34 PM
Padawan's Avatar
Darth ModerVader
Default Re: disassembly of rear lights (mikeycivic)
The tail lights are not assembled with the same adhesive as the headlamps, and to my knowledge cannot be separated by heating in an oven.
Old Dec 3, 2007 | 12:36 PM
mikeycivic's Avatar
Default Re: disassembly of rear lights (Padawan)
well i am trying it now so we'll see lol
Old Dec 3, 2007 | 12:38 PM
CAM0FLAG3's Avatar
GL, dont hurt yourself now
Old Dec 3, 2007 | 01:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Tail light and corner/bumper lenses use a rigid epoxy, not a pliable adhesive like the headlights.
Your only option is to very carefully cut them open with something like a Dremel cutting wheel and then glue them back together with a similar 2-part epoxy.
If you put them in the oven, you run the risk of deforming the lenses, which will be very noticeable with the tight prismatic hatch pattern present on the lenses. The taillight lenses probably aren't as thick as headlight lenses, either, since headlights have to endure road debris, so they will be even more likely to deform in the oven at the same temperature where a headlight lens would not have any problems.
Old Dec 3, 2007 | 01:40 PM
mikeycivic's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Tail light and corner/bumper lenses use a rigid epoxy, not a pliable adhesive like the headlights.
If you put them in the oven, you run the risk of deforming the lenses, which will be very noticeable with the tight prismatic hatch pattern present on the lenses.</TD></TR></TABLE>
awww fack that then
5G_Vtec
Mar 22, 2007 11:27 AM
Giga Crusher
Apr 24, 2005 05:22 AM
01IntegraSE
Apr 23, 2003 01:12 PM
MikeyDB7
Mar 5, 2003 02:43 PM
